Hi,
I would like to draw your attention to a serious iMac hardware issue, that consist on failing LCD‘s (since the G5) that shortly after a year of usage(sometimes even less!) start to develop colored vertical lines from top to bottom 1 or 2 pixels wide. The problem is so sever that on the Apple forums, there are two threads of which I am giving you the links, with lots of users having the same problem.
http://discussions.apple.com/thread.jsp ... 6&tstart=0
http://discussions.apple.com/thread.jsp ... &tstart=15
As you know, the replacement of the iMac LCD is expensive, around $700.00 USD depending on the country and of course, most of the affected people, does NOT have extended warranty service. It seems to be a defective batch of LCDs with certain serial numbers, but so far Apple has refused to acknowledge this problem and therefore honor the affected users with an extension on their warranty for the LCD replacement.
Enrique Diazruanova
Intel iMacs developing vertical lines on their LCDs'
- Diazruanova
Windows 7 Home Premium 64bit
CPU: Intel Core i7 860 @ 2940 MHz // GPU: ATI-Radeon HD 5670
MotherBoard: Gigabyte H55M-USB3 // RAM: 8Gb // Audio Card: Audio Card: M-Audio Audiophile 2496
Cubase 6 x 64 Bit 6.0.4
The Grand 3 ver. 3.1.1 64Bit // Halion Symphonic Orchestra 1.5.0 x 64 Bit
EWQLSO Symphonic Orchestra GOLD 64Bit (Play 3.0.21)
Unfortunately, this is nothing new:
http://www.crosspond.com/apple/home
I guess it can be very difficult to maintain quality control when your manufacturer is half a world away. Just ask Mattel.
- Diazruanova
Wow, this is really an eye opener! Thanks a lot cuttimecuttime wrote:Unfortunately, this is nothing new:
