Is the Tascam US 224 a good solution ?
Gibble
Post by Gibble »
I am thinking about getting a portable controller for DP. Does anyone out there have any experience with the US 224 ? Will the 224 work for moderate audio editing and processing? Most of the audio is pre-recorded prior to being fed into DP.
If not the Tascam US 224 are there any other options ?
Thanks for the feedback
Powerbook G4 1Ghz, 768M Ram, GEM RPG800. For vocal lesson recording: Behringer MXB1002 mixer, 2 x Behringer ECM 8000 omni mics, 2 x Behringer C2 cardiod mics, Edirol R-1. For recital recording: Alesis FireWire Multimix 16, 2 x Studio Projects C3 and an AT835b for vocal focus.
BradLyons
Re: Is the Tascam US 224 a good solution ?
Post by BradLyons »
If all you need is something inexpensive for audio in/out and a basic control-surface, this is just fine.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Shooter
Post by Shooter »
I mainly use the 224 for its MIDI inputs and the transport controls. However, the faders work fine for simple mixing and it's easy to switch banks in DP and have it follow along. For basic stuff it works. I think DP actually implement's the US224 better than Logic, at least Logic 6 haven't used it as much in 7. The controller works intuitively in DP, with Logic I find I have to use strange combinations to get things to work the way I want.
Dual 2.5, 2.5 GB Ram, OS 10.3.7, 250 GB 7200 RPM Audio Drive, 200GB Maxtor External FW (Sample) drive, DP 4.6, Logic Pro 7.1, Reason 3, Live 4.1.1, Peak 4.13, MOTU 828 MKI, Tascam US-224
"All the salty margaritas in Los Angeles, I'm gonna drink 'em up."
