so i switched from using an alienware to a macbook pro to write tunes with
i have a motu traveler with firmware upgraded to 1.07
the macbook is running windows XP pro
and........
no joy at all here
anyone out there have any idea how to resolve this without reverting to extreme acts of violence.....
any help is much appreciated
mattyc wrote:so i switched from using an alienware to a macbook pro to write tunes with
and........
no joy at all here
I was installing Ultralite with MacBook Pro 2.16Ghz with Boot Camp 1.4 and Win XP Pro SP2, was encounter glitches on all outputs.
After I upgraded Ultralite firmware from v1.0 to 1.15, the CueMix Console was still unable to sync with the Ultralite.
Here are 3 Windows XP Pro patch files for people that facing CueMix NOT SYNC or Windows crashing problem when try to play Windows Media Player. After running these 3 patch files, all problem will SOLVED after you RESTART Windows.
**You can click on the following link to retrieve your File. The link will expire in 7 days from 26th September 2007 and will be available for 100 number of downloads.
and........
no joy at all here
just to double check, are you 100% sure its running perfectly since installing those updates?
Im running an ultralite and am having heaps more luck since installing the patches, however still get weird problems where audio will run beautifully for an hour or so and then completely crap out with the weird vinyl pops n crackle problems..this can happen at any time, wether in an audio app or not.
Id be interested to know if anyone has a rock solid motu firewire device going under bootcamp/xp on a macbook pro
I have XP, bootcamp 1.4, & Traveler, running well on Macbook
not Macbook Pro but if it's OK on Macbook one would expect it to be OK on Macbook Pro.
See this thread http://www.motunation.com/forum/viewtopic.php?t=23375
The Firewire controller on my Macbook is reported as being -
FireWire/1394 Controller 1
Model : Lucent/Agere Systems (Was: AT&T MicroElectronics) FW322/323 IEEE1394 OHCI FireWire Controller
Version : 1.00
Interface : OHCI
Enhanced Support : Yes
Channels : 64
Speed : 400MHz
and........
no joy at all here
have a nice day
-Dan
I am running the Ultralite with MB Pro & Win XP SP2 fine after the 3 hot fixes (patch files). Before that, was having NOT SYNC issue with CUE MIX.
BTW, I will try installing VISTA tomorrow on my Mac Pro 2.66Ghz. Just got the 30days trial installer from a friend.
have a nice day
-Dan
thanks for the reply, could you send me some more detailed specs on your macbook pro?...ive got the 2.2ghz core 2 duo which i believe is still the latest release (along with the 2.4ghz...didnt even know you could get a 2.6ghz hehe)
at any rate, i wouldnt think there are many differences between our machines. are the 3 patches you installed the only things you did?...have your run any other xp updates since installing xp (do you have auto update turned on?) does your macbook have the texas instrument firewire or the lucent one mentioned above? what version motu drivers are you running (software? firmware?)
and........
no joy at all here
I can‘t make my dual MOTU 896hd thru Windows XP UE sp2 installed in my Macbook Pro under Cubase/Nuendo. It crashes when I change into the program to MOTU ASIO drivers, and when I‘m out of Cubase/Nuendo I can‘t run the CueMixer, saying that "the device bus can not support this transfer rate". But when I‘m under MAC OSx Leopard I can run perfectly Digital Performer 5 with no sync lost or crashing problems.
I don‘t have this problems with the dual MOTU under my Mac Pro/Windows XP. I can run it under Cubase/Nuendo without any problems.
Could I try this patches? Could you please reseed it?
Thanks a lot!
Dynamita Studio
MAC Pro 2,66 Intel Xeon
Macbook Pro 2,16
Dual MOTU 896hd // Truth 2031a
Focusrite ISA´n´Joemeek preamps
Lots of plugs / AKG ´n´ Shure mics
