Toodamnhip,toodamnhip wrote:MIXOSAURUS wrote: Lets say I play a one bar loop at bar one of my song, if there IS a soft snare first time you play the loop, let's say on beat 4, will it always be softer on beat 4 or will the alternating soft sample vary each time so that the next time I play bar one, the soft snare might be on beat 2?
sorry - I forgot this one. The answer is yes - and no
The sample alternatives use the round robin feature. Normally, the counter would go round and round - if you stop the sequencer and the last played hit used sample 4, then the next time you hit PLAY it would start with sample 5. That's the version you don't like: slightly different playback each time.
The good news is that KontaktPlayer2 allows you to reset the sample engine - which also resets the round robin counter.
With a simple click on the button (reset takes 2 seconds) you can achieve identical playback each time.
If it's not a "song" situation but rather a "loop" situation, then it's even easier as you can simply load a patch that has the "right" number of alternating samples to NOT shift: If your looped bar has 5 snare notes in it, you'd load a "5 alternating samples" patch for the snare and this would make every instance of that bar play identical samples.
So again - you choose. If you like random deviations to keep it "alive" - possible. If you like to have identical deviations in each pass - possible. If you like static playback aithout any deviations at all - possible.
Thanks for asking!
MIXOSAURUS
