Yep,that's it.azusa749a wrote:Thanks.Akai96 wrote:1 MIDI time piece II,and a MIDI time piece 1.azusa749a wrote:What MIDITimepices do you use. I still have the old one collecting dust.
Are they connected through the Network connection, right ?
Very True. Using Logic and DP make a great companion. I actually run them together on the same machine and route the audio via soundflower. I still use the MIDI sequencer in logic for the VI's and just route the audio...And everything stays in perfect sync. Its pretty cool when I got Logic and Reason running at the same time slaved to DP. You get the best of both worlds.Akai96 wrote:I just think that it's cool that you can use the two best music apps,and all of their individual features at the same time,and to get them to operate as one machine is just amazing.
What settings do you use to run Logic and DP together on the same machine?I actually run them together on the same machine and route the audio via soundflower.
Yak wrote:What settings do you use to run Logic and DP together on the same machine?I actually run them together on the same machine and route the audio via soundflower.
Rewire or MTC or something else?
I want to be able to run them together as well. I prefer to use DP for MIDI, audio edits and mixing but, I like some of Logic's plugs and synths.
Yak
Good ol' Shooshie - our resident reality check.Shooshie wrote:MOTU debuted that feature in December 1997 in Performer 6 and Digital Performer 2.3. It's still there. It's under "Search" in the Edit menu. And it does much, much more than that. Select by rhythm, position, velocity, note, "similar to", and many other criteria, plus you can layer the criteria for very complex searches. Once you've done it, save your search and the next time you want those criteria, all you have to do is click that saved search in the menu. Can't beat it! Click here and check it out.
PS: that feature was suggested in detail by yours truly for a couple of years, along with many others, and they finally added most of them at that date. Some of the others, like color-coded MIDI tracks sharing a single edit window, would have to wait a few more years. Hey, it's the truth, and I can't help it if modesty is difficult for me.
Oh, Yes...It is possible to MIDI sequence Logic instruments in DP, but it can get fairly complicated and annoying to deal with (routing MIDI and such). I just found it easier to MIDI sequence logic VI's in logic, then just route the audio via soundflower to a stereo track in DP. Once you have what you want from logic, record that material to the stereo track in DP. And of course as far as editing and mixing your takes you use good ol' DP. This is exactly how I do it when I slave reason to DP via rewire - just keeps it simpler for me.Yak wrote:
Yak
Shooting in the dark here, but, maybe you could trouble shoot (if the sample rate fix doesn't take care of it) by assigning one app to a different soundcard, i.e. the computers core audio internal sound. A different audio interface/soundcard probably will have a different latency- this is just to see if both run then. If so, perhaps core audio doesn't support multiple applications simultaneously accessing one interface, or at least your version of core audio- maybe a different OS10 revision or different MOTU version, or focusrite drivers- or maybe just the focusrite wouldn't be compatible with that feature. Or try DP or Logic in MIDI only mode and see if they both run and sync, and build from there.IAMLFO wrote:This is great stuff! I have both Logic and DP and since I am new to DP working with them in tangent would be very cool. I've followed the steps, but I seem to have an issue with DP. I start DP and then start Logic. When Logic starts I get a message from DP saying that my audio card has changed and then DP gives me the beach ball of eternity. Is there a setting I need to use so the two programs can share my Focusrite 26 I/O?
-Kevin
