I have some plugins I've created using SonicBirth... Does anyone know where/how to save the plugins so that DP will load them when opened??? I have the option of exporting them as AUs or VSTs, but I'm not sure when to save it so that DP will load them.
Please help!
Arthur
Sonic Birth, using new plugins
Powerbook G4; 1.67 Ghz; 1.5 GB Ram
DP 5.12
Pro Tools 7 LE
Mbox
DP 5.12
Pro Tools 7 LE
Mbox
Hi
Read the Sonicbirth manual.
Quote:
5.2.7 Exporting the plugin :: Ready to try out your plugin in your usual audio host? Use the File menu, click
export, and choose a destination.
You can then install it in the appropriate location. Simple. (To export in VST format, simply hold the option key while
choosing the export menu item.)
Save new plug-ins as AU plug-ins.
Put your AU plug-ins in the Components folder.
Library > Audio > Plug-ins > Components
DP should scan all the new plug-ins when you start it up.
jarok
jarok
