Using external waveform editor, Peak and reload??
hiromiito
Post by hiromiito »
I need to edit some stuff on some soundbites in my project. I double-click the file and edit in peak. Somehow it doesn't want to be saved as it is, and i can't reload it afterwards.
The file in Peak has also all those regions. I don't know what to do to save it properly and have it right back after using the reload command in DP.
Anybody knowing the procedure? That'd be so helpful.
1pauper1
Post by 1pauper1 »
i bought peak pro xt a month ago and i'm in the sane boat
as you are. i can do a lot of stuff, but i can't figure out how
to actually apply it to a track permanantly.
when the aliens finally come to conquer the earth-
let us hope that their weapons of choice are
fender telecasters and macintels !!
kassonica
Post by kassonica »
I kinda remember doing this a long long time ago and i think you have to save it as a SD2 file.
I might have this wrong as i've been tracking 30 hours out of the last 48 but i digress
valleysound
Post by valleysound »
I've got Peak 4.13 and I don't have any problems. I open the file in Peak and edit as I need then "save as" using the same file name and location. When I open a DP file that the edited file is part of, DP will will examine and reload the file again. When using DP I use only .SDII files. Hope this helps.
Paul Magro
Owner/Engineer
802.356.7001
www.ValleySound.net
