I Need Help Cutting Off The Sound of Each Sample As It Plays
I have four Parts, each assigned to the same MIDI channel and same outputs. Each part begins on the downbeat one after the other in a 4 bar loop. Basically, I'm trying to get part#2 to cutoff part#1 and so on as it cycles through each bar. Does anyone know how I can achieve this? Thanks.
You can't have one part affect another - as far as I know. Is each part being triggered by a different note? If so, just move all the release evenlopes to zero so they cut off immediately . If these are beat loops, why not just move them to Audio files and edit that way.
MacPro 8 core/DP 5.12/Mach5v2/HD192/24io/(2)2408 Mk3/(2)MTP AV/UAD-1/Powercore/Spectrasonics/NI Komplete/BFD/Ivory/Arturia/Plugsound Pro/Dimension Pro/Nord Stage88/Gigastudio/V-Stack/MacBook Pro
