hi guys
OK i finally got my new iMac 2.4 yesterday (which i will dedicate another thread to). OK setup assistant, migration assistant and firewiring my old mac's HDD haven't worked. I have the firewire symbol on my old mac but nothing on my new iMac. migration assistant nor mounting the old mac via target mode - nothing works!!
any suggestions?
k
Serious mounting issues
- jimbyjoe
Consider how much coffee you're drinking..
...it's probably not enough.
iMac 20" 2.4GHz
MOTU 828MkII
Digital Performer 5.12
Guard dog: Cattle dog
iMac 20" 2.4GHz
MOTU 828MkII
Check your cables to make sure they are firmly seated.
Check About This Mac to see if the computer sees something connected, even if it says "unknown".
Check Disk Utility to see if the unknown drive appears in the list but is marked as being unmounted. If so, click the button at the top to mount the drive to see if that works.
If all else fails, use your older computer to back up the drive data first. Then reformat your drive using the Disk Utility on your new computer. Once it mounts, restore your drive data on your new computer.
- jimbyjoe
hi frodoFrodo wrote:Check your cables to make sure they are firmly seated.
thanks mate. there appears to be an issue with this, after checking various forums. no it doesn't show up in disk utility.
k
iMac 20" 2.4GHz
MOTU 828MkII
iMac 20" 2.4GHz
MOTU 828MkII
Sorry... just checking this thread for porn.
