Intel MacBook Pro with DP4.61
I just bought a MacBook Pro (2.4 GHz Core 2 Duo with 4 GB of memory) and I‘m running DP 4.61 on it, but several times since I‘ve had sessions open, it unexpectedly quits on me. Is this a common problem with DP 4.61. Would an upgrade to DP 4.5 be worth it?
kristupes
Hi
It is definitely worth it to upgrade to DP 5.11.
Here is more info:
http://www.motu.com/techsupport/technot ... quirements
jarok
Here is more info:
jarok
Delete your Audio Unit Info Cache found in you User Library>Preferences> Digital Performer folder. Restart DP for a rescan.kristupes wrote:Thanks. I updgraded to DP 5.12, but now it can‘t find Ivory, Atmosphere, Altiverb and MachFive. What can I do to use these plugins in the new version?
If that doesn't do it, make sure you have the latest versions for your plugins and that they are indeed Intel-compatible.
You'll need Ivory 1.5 or later (current: 1.63), Altiverb 6.0 or later (current: 6.1), MachFive 2.0 or later (current: 2.01)...
Now, Atmosphere sounds can be played in M5v2, but the actual plug is not Intel comptible.
Check here for workarounds and caveats...
http://www.spectrasonics.net/news/Worka ... l-Mac.html
- emulatorloo
You have an intel mac. Therefore, all of your plugins need to be intel ready. Frodo gives more detailkristupes wrote:Thanks. I updgraded to DP 5.12, but now it can‘t find Ivory, Atmosphere, Altiverb and MachFive. What can I do to use these plugins in the new version?
Note that DP 5.1 and above is required for intel macs.
FWIW:
http://www.motu.com/techsupport/technot ... earchterm=
Using Plug-ins in Digital Performer 5.1
Digital Performer 5.1 is a universal binary application, meaning that it runs natively on either PowerPC or Intel Macs. Per OSX's design all applications & any plug-ins they use must run entirely natively or non-natively. This means that with DP 5.1 you must use plug-ins that are also universal binaries or that are specific to the type of Mac you have (i.e., PowerPC plug-ins on a PowerPC Mac).
If you're running DP 5.1 on a PowerPC Mac, you can use universal binary and PowerPC-only plug-ins. You cannot use Intel-only plug-ins.
If you're running DP 5.1 on an Intel Mac, you can use universal binary and Intel-only plug-ins. You cannot use PowerPC-only plug-ins.
All of the plug-ins included with Digital Performer 5.1 are universal binaries.
