I can't find the Mapping Editor. Please Help.
First, I load a .WAV sample into the Parts section by double-clicking on the Parts window. The problem arises when I try to get to the Mapping Editor once the sample is loaded. I see the waveform of the sample in the display window, but I can not get the Mapping Editor to appear. I know you are suppose to click on the Info Window, but it does not appear. What am I missing? Thanks.
- Shooshie
Directly above the keyboard you should see a margin with some words in it: "Select:... Root:... Key:... Vel:..."
Directly above that space is a blue line. Grab it and pull up. Map editor expands and appears. Ta-daaaaa!
Loading a single sample in an empty part opens the sample in LoopLab. You'll know you're in LoopLab because the Keygroup and Layer sections of the MachFive window change to a LoopLab section. If you want to load a single sample to a part without opening it in LoopLab, you have to drag it directly onto a key in the Mapping Editor.
