First impression of M5.2 - very positive!
danworks
Post by danworks »
gavspen wrote:
danworks wrote:SNIP ... By the way, you have a dedicated HD for your library, don't you? :)
Yes I have a dedicated drive :) I guess I'll try streaming and see how it goes, and thanks Dan, for that link to MenuMeters.
I'm, still curious though; what happens when you guys try to exceed available RAM? To have it crash is not helpful. Anyone get an error message instead?
Honestly I never deselected the streaming option for most parts, only on those parts w short samples (percussion) where the streaming isn't really necessary so, I never got any error message.
gavspen wrote:And by the way, lest this should all sound too negative, that's about my only complaint. I think for $200 it's a very good upgrade. Gavin
I have some complaints too, basically in the graphic area
Between me and my 22" screen there's an 88 keys and at that distance some of the M5 fonts are too small, other fonts have poor contrast compared to the background, some button looks selected while are deselected (LFO's "GLOBAL"), other deselected buttons like MIDI SELECT, are impossible to read. As I wrote there's still room for improvements. ;)
"Leave the gun, take the cannolis …"
#1- MacPro-12Cores 3.3Ghz /64gig RAM/MacOS 10.13.6/DP10/VEP6/PCI-424
#2- MacPro-12Cores 3.3Ghz/64gig RAM/MacOS 10.10.5/VEP6
UAD2 and lots of software and plugs
Solo project here and on iTunes
gavspen
Post by gavspen »
Shooshie wrote:I haven't had the problem yet, gavspen. I did have a beachball freeze when I tried to convert one of those large piano samples into RAM-based, and not streaming. I just toggled-off the "Streaming" button, and the ball started spinning. Pretty soon it just quit.
Perhaps I dont have the nomenclature right (after all these years!); crash, quit, freeze.....sounds like you're getting just what I'm getting Shooshie; when trying to load a big preset, NON-streaming, it churns for a while, then comes the beachball, then it just disappears from the screen. Is that a "quit", not a "crash"?
Gavin
danworks
Post by danworks »
Gavin
Technically it's an unexpected quit, but if you go here:
user/Library/Logs/CrashReporter
and you find a log, then it's a crash.
Post by Shooshie »
Gavin
Well, I didn't tell the whole story. I got tired of waiting on the beachball and did a force-quit. There was some general chaos going on at the time, so I am not sure whether it quit on its own or after my force-quit, but I definitely sent it the force-quit signal and confirmed it with the OK button in the Force-Quit Dialog.
Post by Shooshie »
The more I use MachFive2, the more confident I feel in standing up here and shouting out:
MachFive2 is incredible! Buy it!
:D:D:D
nk_e
Wow
Post by nk_e »
Got M5v2 upgrade last night.
1 - Installation is relatively painless. A little concerned when I saw the "chip on a card" that I had to insert in my iLok, but smooth as silk it was.
2 - The sounds are OK. Not blow your mind great. Not embarrassing. Certainly enough "to get going with" if this is your only sampler.
3 - Opening others sound formats is pretty transparent although there were some funky instances of Apple Loops playing immediately upon import without a key being touched. Happened several times in fact. For every EXS24 patch I opened, I had to manually locate the sample directory even though the samples are installed at their default location. So even when it said can't find sample at "user/library/applicationsupport/blah/blah" if I pointed to that exact same directory and said "find it", it would then load the samples. weird.
4 - As a Kontakt user I have to say working with M5v2 is extremely intuitive. I've created several sounds (albeit simple) that I enjoy - just by clicking around and trying things. IMHO Kontakt does not lend itself to that type of spontaneity without significant investment in time grokking the program.
That means there's less between me and creativity. A good thing.
Peace,
GN
4 -
