Macbook Pro ? regarding sleep mode
Pound
Post by Pound »
I just got a macbook pro. My question is...Do I leave this thing on all the time so that it can run it's nightly scripts.....or do I shut it down when I'm not using it? I read somewhere that osx 10.4.10 doesn't have to stay on all the time, but I can't remember where I read that and I can't find the info to varify it again.
Macbook Pro
OS X 10.4.11
DP 5.12
Motu Ultralite
Frodo
Post by Frodo »
One question to ask is whether you really need to run scripts every night.
You don't *have to* shut down, but there are some considerations:
I've not heard of any benefits of leaving the compute running even if some claim that they rarely or never shut down. I have, however, heard plenty of good reasons not to leave the computer on all the time.
Sleep mode is still not good if you are running a DAW. Should the computer go to sleep with a session open, the session *might not* recover without a reboot. Disabling automated functions in general is a well-known system optimizing tip for DAWs.
If hard drives are set not to spin down during a DAW session where virtual memory has to rewrite pages of data and deliver them to RAM on time, shutting down the computer gives the HD a rest.
A cool computer is a happy computer.
Shutting down is a good way to flush virtual memory and old file references. This can be done intermittently, but there's no reason to leave the computer running unattended for hours at a time if it's not necessary.
If you choose to leave your computer on, make sure you have good reasons for doing so beyond those of personal convenience.
Just my 2•
rcannonp
Post by rcannonp »
I shut mine down. I think it just needs a break sometimes. Third party utilities like Onyx(free) and Cocktail will let you run cron scripts, repair permissions, and do some other system maintenance chores.
15" MBP - 2.4 GHz, OS 10.4.11 :: DP 5.13, Reason 4, Live 6.0.7 :: MOTU 896 :: Korg MicroKontrol, Casio CDP-100
Pound
Post by Pound »
Thanks guys. I didn't want to leave it on all the time anyway. I'll stick with shutting it down and running onxy to clean up and maintain.
Macbook Pro
OS X 10.4.11
DP 5.12
Motu Ultralite
sdemott
Post by sdemott »
I've been been using PowerBooks (now a MacBook Pro) since the 180c. I only shut down when I need to restart or store for long periods of time. Rest of the time they sleep.
Little known fact - Apple considered removing the shutdown command from PowerBooks at one time, and there are 2 models of PowerBook that actually did this - not by removing the Shutdown command, but by having the Shutdown command trigger a "deep sleep" mode, rather than causing a true shutdown. (extra points to anyone who can name the models)
BTW - there is no reason to run maintenance utilities if you're not having problems. If you have a good understanding of UNIX and know when/why to run the scripts...have at it, otherwise my advice is to leave well enough alone. The OS is generally very capable of taking care of itself.
-Steve
Not all who wander are lost.
Frodo
Post by Frodo »
sdemott wrote: Little known fact - Apple considered removing the shutdown command from PowerBooks at one time, and there are 2 models of PowerBook that actually did this - not by removing the Shutdown command, but by having the Shutdown command trigger a "deep sleep" mode, rather than causing a true shutdown. (extra points to anyone who can name the models)
I probably won't earn any points here, but trivia is fun!
The October, 2005 PB models introduced a hibernation mode, but I'm not sure about the extent of this feature because other models, including MBPs, at least one Mac Mini, a MacBook, and a 2006 MacPro can also support this feature. There was a widget floating around at one time actually called Deep Sleep which supported at least a half dozen machines, at least three of which are laptops.
Chalk it up to a good guess! :P
Pound
Post by Pound »
Thanks for the additional reply. Not sure now what to do. haha
Macbook Pro
OS X 10.4.11
DP 5.12
Motu Ultralite
sdemott
Post by sdemott »
Trivia is fun :-)
Even farther back...we're talking 680x0 based machines. Anyone else care to guess before I break the suspense?
-Steve
