Logic Xpress & PCI 424. No sound on the Bus...
Bertzkii
Post by Bertzkii »
Hmm, seems like I have a problem...
Opening up a project
Using the 24 track template
Choosing 2 tracks and sending them to Bus 2,3,4, 5, (i.e. changing the output on the track) or what ever
Output on bus 2 is set to 1-2
No sound...
Can it be my MOTU PCI 424 giving me a hard time?
It is working with my Built-in Audio card...
emulatorloo
Re: Logic Xpress & PCI 424. No sound on the Bus...
Post by emulatorloo »
Bertzkii wrote:Can it be my MOTU PCI 424 giving me a hard time?
Maybe you need to make some settings in the "MOTU PCI Audio Setup" application?
Bertzkii
Post by Bertzkii »
Yeah, maybe....
My 2408MkII is the default and Input and output says 2408:Analog-A 1-2
I have also marked off Enable Routing
Bank A Says analog and I have anabled Input and Output
1-2
3-4
5-6
7-8
on my 2408MkII
my 1224
is configured the same so I can use 12 in 12 out (Limitation of Logic E)
I've tried to delete the pref of Logic to see if that's a prob & I have also repaired the permissions. Nothing have helped so far...
Bertzkii
Post by Bertzkii »
Updated Logic to Logic Pro 7.2 and now it works like a charm:-)
