would some generous soul enlighten me regarding importing OMF in dp.4.52.
i have an omf project on my desktop that i would like to mix but my dp. doesn't seem to see it.
any suggestions would be greatly appreciated.
importing an OMF project into DP. 4.52
- gearboy
I use DP4.61. I imported a 16 track OMF file that was created in, I believe, Final Cut Pro, in like 1 minute, with video window, timecode etc etc. The first project that I did with video sync.
Anyway, I am assuming that 4.52 is the same as 4.61, but it is a free update so you can step up.
Make sure that the OMF contains only mono files, no stereo files. I have heard that this makes or breaks the import, most likely due to the SDII .L/.R thing. I just know that the OMF that I had imported fine and was all mono files.
Hope that this helps.
Jeff
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
thanks for the tip gearboy.
according to the fellow who made the omf file there are no stereo tracks contained within it.
interestingly, i now have the same project on a dvd that is just wav. files and i can't seem to import that either.
the files were generated using cubase on a pc.
i don't usually have any problem importing wav.
i'm feeling rather at a loss to know what to do next.
is it operator error or is it some sort of compatabilty issue?
any thoughts would be much appreciated
rawk on.
