Effect Error
niken
Effect Error
Post by niken »
Hello,
When opening an existing project with effects I get the message "effect error, the following effects could not be found"
All the DP plug-ins are listed in that window.
Can someone help me out please?
Kind regards
Mac G5 OSX 10.5.8 Motu 2408 MK3, DP 4.61, BFD
FMiguelez
Post by FMiguelez »
Hi.
Is it a DP or a 3rd party plug?
If the latter, make sure you didn't move the shell from the folder it is supposed to be. I would look if it's there.
niken
Post by niken »
Hello
The standard audio plug-ins that comes with DP 4.5
No third party
I discovered that all off the plug-ins are back except the master works limiter and the master works EQ
And I did nothing??
Also I can't point out the apple software synthesizer to other instruments within that library?? I can't make a patch change?
I didn't move anything
jarok
Post by jarok »
Hi
Set the language on your computer to english.
This kind of problems have been appearing if the language is not set to english.
I hope this helps.
jarok
niken
Post by niken »
Hello Jarok
I switched the language to english but it didn't help
I still miss the Masterworks EQ and Masterworks Limiter
jarok
Post by jarok »
Repair Permissions with the Disk Utility.
Disk Utility is inside the Utilities folder.
You can also trash DP preferences found in:
User Library > Preferences > Digital Performer•„• > Preferences
Then restart computer and open DP.
