Reset Faders and Pan Knobs
Trachnyne
Post by Trachnyne »
Is there a quick way to reset all of the volume faders to zero and pan knobs to center in the mixing board? And for that matter, the sends as well?
Trachnyne
http://spaceorangemusic.com
Mac Pro Dual 3ghz / 2GIG RAM / Leopard 10.5.1 / 2 MOTU 896 / DP 5.13 /
magicd
Post by magicd »
Double click on a fader or send to reset to 0.
Double click on a panner to reset to center.
To reset multiple tracks simultaneously, display those tracks in the mixer. Hold Down the W key and Pull a fader down to zero. All faders will go to zero. Release the mouse button and W key. Hold the W key down again and double click on the fader. All faders jump to zero.
The W key temporarily groups the volume fader or pan knob. It does not affect the sends. You'll have to reset the sends individually.
Magic Dave
Appalachian Boy
Post by Appalachian Boy »
magicd wrote:Double click on a fader or send to reset to 0.
Magic Dave
wow i learn something from every thread. thats why i love this forum
Mac Pro, 828 MK1x2, Beer....what else?
Trachnyne
Post by Trachnyne »
Magic Dave
You're a life saver! Thank you!!!
Trachnyne
Tim
Post by Tim »
If there many many tracks, rather than adjusting each send individually, it may be faster to make a snapshot of all send levels, then use Region/Change Continuous Data to adjust it on all selected tracks at once. Hit play to make levels change, then erase send automation (or disable send automation then Undu to before the Snapshot was made) if desired. I'll usually go to Setup/Automation Setup and Option click (to enable only) Sends before doing this operation (set it back to normal afterward).
I think that the Audio Assignments window should have Send Assignments in it too.
lodstudios
Re: Reset Faders and Pan Knobs
Post by lodstudios »
The reason I love this forum! It always pays to search before you ask, it saves so much time! Thanks for the tip, now back to mixing!!!
Keith
IMAC 2GHz Intel Core 2 Duo, 4GB RAM, 250GB Drive
Millennia STT1, POD Pro, Lucid Genx192, Neumann TLM103, Mackie Big Knob, Mackie HR824, Sterling Audio ST31, Yamaha P90, M Audio Axiom49 X 2, DP 6, Intel IMAC 2GHZ, 4GB RAM, Miroslav Philharmonik, Synthogy Ivory Grand Pianos, Mach 5 2, Sampletank, EZ Drummer, Waves Renn. Bundle, T-RackS 3 Deluxe, Amplitube.
Keith Orfanides
Engineer/Producer
Light of Day Studios
http://www.lightofdaystudios.com" onclick="window.open(this.href);return false;
http://www.myspace.com/lightofdaystudios" onclick="window.open(this.href);return false;
