Anyone use the Yamaha USB driver?
PeterMcCStrat
Post by PeterMcCStrat »
Usually the Yammy drivers are real bad,. anyone using it well?
how bout the UB version as well?
thanks
Peter
Mac Pro 2.66 | 4GB ram | OS 10.5.4 | MacBook Pro 2.4 | 2GB ram | 10.5.4 | Apogee Ensemble | Apogee Duet | DP 6.01
bmills3
Post by bmills3 »
Been using the USB-MIDI driver fine for both PPC & UB with 4 different Powerbooks and now MPB. All have worked fine, but you're best off to check www.yamahasynth.com for latest updates. I don't have any experience with USB audio drivers, so if you're talking about that, I'm no help.
stephen1212b
Post by stephen1212b »
Works here with thier hardware.
Mac OS X version 10.5.8 / DP 7.12 / Dual 1.25 GHz G4 2GB DDR SDRAM / MOTU 2408mk3 / Powerbook G4 / traveler
USB MIDI works great with my Motif ES and hte Yamaha driver. I did have to break the ground/shield connections on the Motif USB cable to eliminate a low-level ground noise in my 828mkII.
https://rbohemia.com
PeterMcCStrat
thanks Guys,
anyone use the Studio Manager software with the Motif on a Mac Pro and DP?
Peter
chadd
Post by chadd »
HCMarkus wrote:USB MIDI works great with my Motif ES and the Yamaha driver. I did have to break the ground/shield connections on the Motif USB cable to eliminate a low-level ground noise in my 828mkII.
I had a hum in the audio outputs of my S90 synth when connecting it via USB. I found that unplugging my USB printer improved it significantly, but I'd be interested in details of how you modified your cable.
Sorry to drift off topic. The Yamaha USB-MIDI drivers have been working well for me in OS 10.3.9 on a G4.
seasiderecording
Post by seasiderecording »
I use the usb with my S90 es. MIDI works fine. I am frustrated with trying to get the studio manager to work. Very poor documentation.
chadd wrote:I had a hum in the audio outputs of my S90 synth when connecting it via USB. I found that unplugging my USB printer improved it significantly, but I'd be interested in details of how you modified your cable.
See this: http://www.unicornation.com/phpBB2/view ... usb+ground
I concur: Studio Manager documentation sucks big time.
PeterMcCStrat
thanks guys,
I noticed on my Powerbook that using the USB driver and SM Software, the patch names are not available within DP anymore.
seems strange?, is this correct?
thanks
Peter
Motif ES Patches are still available in DP for me via the USB connection, but I don't use Studio Manager. I was left confused and frightened by my experimentation with this incomprehensible creation of Dr. Yamaha. I now just say "NO."
scooter
Post by scooter »
I've got the Yamaha Motif XS7. I can't see how using the studio manager software could be of any help unless maybe you use Cubase.
Scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
scooter wrote:...I've got the Yamaha Motif XS7...
My dream machine. :shock:
You bugger. :?
Any word on whether a rack version will come out?
PeterMcCStrat
scooter wrote:I've got the Yamaha Motif XS7. I can't see how using the studio manager software could be of any help unless maybe you use Cubase.
Scooter
I am a former Nuendo user and yes,..DP has much better MIDI features but still,..
Studio manager lets you adjust each patches tone, and effects etc,..
Lets you select what master effects.
it was integrated into the Nuendo project so the type of effect and EQ of each Motif part would open with each project.
This works way better for me as I'm not a keyboard player (don't sit in front of the MotifES) and can't stand being hunched over scrolling through that tiny Motif screen.
All things handled in one place rather than 2.
Also the voice editor that works to edit each part in the same way
I figured that saving the SM software as a startup clipping in DP would be similar to how it operates in Nuendo.
But not if I can't see the patch names in DP
Not worth it, I rarely even use the Motif ES anymore, little at a time I've replaced all sounds I need with great soft librarys.
So, guess I'll just stay old school.
thanks
PM
scooter
Post by scooter »
Yeah, what I guess I'm saying is that it looks like Studio Manager is a great thing if you have Cubase because it actually lets you bring up you Motif XS as a plug in within Cubase with the patch list and each patch list can be edited. But that feature is not available for D.P. users. Oh well. Has anyone had any luck with Cubase 4??
scooter
markg
Post by markg »
Is there a way to disable the extra ports so they don't show up in DP?
In Audio MIDI Setup I added a "YAMAHA ES8" device and connected it to Port 1 of the ES8 interface. This shows up fine in DP but I also get 8 "YAMAHA MOTIF ES YAMAHA MOTIF ES Portx" (one for each port).
Is there some way to remove these extra ports?
Mark
