converting DVD to quicktime movies
sjpc0
Post by sjpc0 »
Hi All
I'm working on a soundtrack for which the producers are sending me scenes in DVD format. DP needs quicktime movies. How do I convert these to enable them in DP?
thanks
AC
G5 2ghz, 2.5 gigs RAM, OS 10.4.9, DP 5.1, RME Fireface 800, UAD pci, Stylus RMX, Absynth, Kurtzweil 2600,
jstaczek
Post by jstaczek »
Jason Staczek
www.chromasound.net
Dual 2.5G G5, 6.5G RAM, DP 5.13, OS 10.4.11
MBP 17", 3G RAM, DP 5.13, OS 10.4.11
Pro Tools HD2 Accel, 828mkII, FastLane, Logic 8
stephentayler
Post by stephentayler »
This is good, free from Apple
http://www.apple.com/downloads/macosx/v ... mclip.html
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
sjpc0
Post by sjpc0 »
Thanks for the replies
I don't have the MPEG 2 playback component. Do I need to buy that first for either the streamclip 1.8 or the handbrake?
cheers
AC
dave pine
Post by dave pine »
just try streamclip, it's free and worked great for me the other day.
mac pro 2.26 octacore 24gigs of ram/ El Capitan10.11, dp 10, mackie dxb, 3-2408mk3, waves mercury 10, ozone 3&4&5678, sound toys, izotope rx, melodyne editor, uad 2, bluetubes, 22" polkadotted dildo, omnishpere 2, trigger 2 deluxe, addictive drums, komplete 9, e/w ql symphonic orq platinum, ql choirs, ql stormdrum 2, ql gypsy, ql ra, ql goliath, ql pianos, superior drummer 3, ez drummer 2, garritan bigband, amg kickass brass, ztar, wife, dogs, droped my protools rig at the city dump
sjpc0
Post by sjpc0 »
Thanks.
Did give it a try.
When I try to open a file--in my case they are VOB files it gives me a blank field with a scroll bar. At various times it tells me to get the MPEG 2 component. I'm doing something wrong it seems?
Any thoughts
AC
stephentayler
I'd buy the mpeg 2 component, it's not that expensive.
kind regards
Stephen
stephentayler
MPEG 2 component is only $19.99, can be downloaded from Apple.
The trick is also to open the correct VOB files, some may appear blank, trial and error is the best bet.
kind regards
Stephen
sjpc0
Post by sjpc0 »
yes, I'll get the mpeg 2 and see what's what.
Thanks everyone
AC
abruzzi
Post by abruzzi »
better off just using handbrake--nothing to buy as it uses MP4, which is natively supported in qt.
Geof
nickysnd
Post by nickysnd »
abruzzi wrote:better off just using handbrake--nothing to buy as it uses MP4, which is natively supported in qt.
Geof
I second Geof, handbrake works great.
Mac mini Apple M1 ♦ 8GB RAM ♦ MacOS 14.4.1 ♦ Focusrite Scarlett Solo ♦ DP 11.31
Mr_Clifford
Re: converting DVD to quicktime movies
Post by Mr_Clifford »
sjpc0 wrote:Hi All
thanks
AC
I just tell them that DVD is an unacceptable delivery format and that I expect a Quicktime file (burnt in timcode yada yada..). It generally gets results, quickly.
I refuse to waste time having to do all the messing around with pulling stuff off a DVD.
sjpc0
Post by sjpc0 »
That is what I usually do but in this case the request illicited a reaction of--we'll have to do this overnight as it will take us hours to output. Thus began my quest.
Mr_Clifford
sjpc0 wrote: That is what I usually do but in this case the request illicited a reaction of--we'll have to do this overnight as it will take us hours to output. Thus began my quest.
I know what you mean. I've done it before in order to get working on the project while they exported the proper QT file and put it in the mail (adding an extra few days to the process).
Ripping the video off the DVD was quite easy, but I had to download an other program onto my Windows 98 PC ('ac3 tool' i think it was called) in order to get the audio into a useable format. After that, I just put my foot down.
