michkhol wrote:FYI: Finder doesn't use cp for copying and it does support extended attributes. Actually it comes from older Mac OS and is totally unfitted for large data transfers. I would also recommend using a dedicated backup software.bjornln wrote:Here's you perp... What are you using to copy to / from ?zed's system.log wrote:Jul 12 08:34:23 PowerMac-G5 cp: error processing extended attributes: Operation not permitted
cp is the copy operation under unix..
"extended attributes" is what unix usually can't handle (or have trouble with)
/B
Jupp, you're right (that's why I asked what was used to copy).. But the ones' I was thinking of are the ones' you can set in windows / active directory.. And as far as I know, you can get in situations that are similar to these.. Or, have they fixed that ?
/B
