You don't -- Soundflower is audio only.davel6332 wrote:How do you get the MIDI?With SF, you get the MIDI too.
You'll need to use the IAC MIDI bus to send MIDI from DP to Logic.
Thanks. When I read what glea said about getting the MIDI, I couldn't figure out how in the world Soundflower would be doing that. Just curious, since I've never used the IAC MIDI bus like this. Is there any noticable MIDI latency between the two applications?davel6332 wrote
Well, maybe I said that wrong, or don't understand what's happening. I hooked up SF, recorded the MIDI in DP as I played a Logic organ. I edited the MIDI in DP and it played back the sounds from Logic. Seems ok to me?davel6332 wrote:With SF, you get the MIDI too.
This is exactly what I want to do, with multiple MIDI tracks in DP controlling multiple sounds in Logic, separately, and being able to assign the audio out puts of the logic sounds to the inputs of DP audio channels...my ideal setup would be a DP audio project, with say, 8-16 MIDI tracks, controlling 8 to16 different, separate Logic sounds, and the routing of the output of those sounds going right back into DP, where you could record it as audio and maybe also monitor the sounds during recording....and then of course record regular audio in DP along with all of that.......is this what you are doing? Would you mind giving a detailed play-by-play of a set up like that, exactlyu how DP, Logic , Sunflower are configured, and tricky tricks or possible unforseen pitfalls that could drive you crazy trying to achieve this...that would be most appreciated, and don't be afraid to be overly thorough and dumb it way down////GRACIAS!!!!!glea wrote:Well, maybe I said that wrong, or don't understand what's happening. I hooked up SF, recorded the MIDI in DP as I played a Logic organ. I edited the MIDI in DP and it played back the sounds from Logic. Seems ok to me?davel6332 wrote:With SF, you get the MIDI too.
this link will explain the set up very clearly (it was already posted, but a good thing is worth repeating)jescoelvis wrote:This is exactly what I want to do, with multiple MIDI tracks in DP controlling multiple sounds in Logic, separately, and being able to assign the audio out puts of the logic sounds to the inputs of DP audio channels...my ideal setup would be a DP audio project, with say, 8-16 MIDI tracks, controlling 8 to16 different, separate Logic sounds, and the routing of the output of those sounds going right back into DP, where you could record it as audio and maybe also monitor the sounds during recording....and then of course record regular audio in DP along with all of that.......is this what you are doing? Would you mind giving a detailed play-by-play of a set up like that, exactlyu how DP, Logic , Sunflower are configured, and tricky tricks or possible unforseen pitfalls that could drive you crazy trying to achieve this...that would be most appreciated, and don't be afraid to be overly thorough and dumb it way down////GRACIAS!!!!!glea wrote:Well, maybe I said that wrong, or don't understand what's happening. I hooked up SF, recorded the MIDI in DP as I played a Logic organ. I edited the MIDI in DP and it played back the sounds from Logic. Seems ok to me?davel6332 wrote:
Remember the original idea was how to use Logic's VI's in DP. So by using Soundflower, essentially what is happening with this setup is that Logic itself is being used as VI's for DP. It's a bit messy and cumbersome, but is the workaround until/unless Apple truly makes the VI's in Logic real AU's (which ain't likely to happen).glea wrote:Well, maybe I said that wrong, or don't understand what's happening. I hooked up SF, recorded the MIDI in DP as I played a Logic organ. I edited the MIDI in DP and it played back the sounds from Logic. Seems ok to me?davel6332 wrote:With SF, you get the MIDI too.
OK...here's where I've gotten to, sorry for the screen shots, but they will give you an idea of what I'm trying to achieve here. In the logic window you will see that I have created a project that essentally is just a repository for 16 virtual instruments, and in the DP project I've created you'll see those 16 instruments reflected in a stereo audio track and a corresponding MIDI track for each of those 16 instruments. I've also included a shot of the sound set up window, which reflects the Soundflower software running (as does the input and output selections in the DP file).billf wrote:Remember the original idea was how to use Logic's VI's in DP. So by using Soundflower, essentially what is happening with this setup is that Logic itself is being used as VI's for DP. It's a bit messy and cumbersome, but is the workaround until/unless Apple truly makes the VI's in Logic real AU's (which ain't likely to happen).glea wrote:Well, maybe I said that wrong, or don't understand what's happening. I hooked up SF, recorded the MIDI in DP as I played a Logic organ. I edited the MIDI in DP and it played back the sounds from Logic. Seems ok to me?davel6332 wrote:
You can do exactly the same with Garageband instruments if you have those but don't own a copy of Logic.
