Ultralite - PC - Ableton Live
Hello Everybody,
Im very New on this and im having some problems configuring......
I Have a PC (Duo 3.0Hz), Windows XP PRO, Ultralite and i want to work with Ableton Live but im having lots of problems with the sound, everytime i want to play something in ABLETON LIVE the sound is not rigth, cutting itself, dont know if buffering problem or processor or memory, i wanted to see if anybody had this kind of problems and now is working good i need some kind help to find out wich is my problem........
Thank you very much in advance.....
Payasin303
Payasin303
Be sure you get the latest drivers from the MOTU website. In preferences, you should be able to set driver type to ASIO, then your Audio Device should show as MOTU ASIO, or something like that. You can then use the Hardware setup to configure the latency. Start it at 1024, and work your way down to see how low you can go with your PC.
If you're not getting sound in ASIO mode, then theres a driver issue. Install the newest one on the website and see if that helps.
Sounds like routing
check your routing. You should be able to get a headphone mix and a separate mix for your main outs. These are not necessarily the same mix. The gear is designed so that you can run a number of main mixes and a number of headphone mixes. At least that is the basis of MOTUs mix routing.
Please read the rest of the posts reagrding MOTU ASIO driver. I have been studying them all week because I can't get anything out of the MOTU ASIO driver no matter driver I use.
RJ
RJ
HP Pavillion DV9500T, 4 gig Ram, Dual 20" Display, 512Mb Nividia 8600 video, 3 SATA HD 7200 RPM 520 Gig max. Cubase VST, SX and 4.02, Halion3, Grove Agent 2, Virt Guit, EWQL Sym. Choir, Voices of Pass, NI Kontakt 2 Kore, Giovani Edition, DIVA, Melodyne Studio 3.2, BFD
Roland JV, XP, D, XV series synths, Korg TR, Triton, O3R/W, M3R, MTPAV (2) USB, Ultralite, Mackie 8 Bus, HUI.
the same
for me is the same, i really cant get sound from my main out, just for the headphones with ASIO working on live 6.0.3
i opened a ticket on motu site and the guys who work there arent helping me to much to fix this..............
Like I said, check the ther posts related to MOTU ASIO and Firewire. I have done a lot of testing over tha last week on this. If you have a RICOH Firewire chipset then forget it, becuase it won't work with MOTU ASIO. I found out the hard way after I bought the new computer!
RJ
RJ
