Mic Test.
- gearboy
Mic Test.
It just so happens that I picked up a few new mics in the past month, and have yet to do any serious projects with them. So tonight I ran a bunch of mics through my Burr-Brown modded MP20 just for kicks as I started recording a demo. All mics were approx 6" away from and aimed at the 12th fret of my 2000 Taylor 310ce. All files are 24-bit/96kHz and 17.9MB each. PLEASE DOWNLOAD THEM, import them into your DAW, and combine them in various ways.
Cascade M37 #1
Cascade M37 #2
Oktava MK012 #1
Oktava MK012 #2
Shure SM57
OktavaMod MK319 (w/ Floating Dome and Premium Electronics Mod)
AKG 414 B/ULS
AT 4047sv
All files were recorded mic --> BB-Modded Presonus MP20 (send to RNC for slight compression in SuperNice Mode) --> Black Lion modded MOTU 828mk2 (analog/clock) --> Digital Performer as 24-bit/96K. If you would like to loop them the tempo is 120bpm, the time signature is 6/8, and I started at bar 4. There is no EQ or processing added, with the exception of slight compression (less than 2:1 ratio at -3db) with the RNC. I used Monster cable for the entire chain (please don't yell at me).
*All mics were recorded as cardioid with no pads or onboard high-pass engaged. I did ude the 80Hz high-pass filter on the MP20 for each recording
Assemble a sound out of 1-4 of these mic choices and post your favorite combinations. I'm curious to see what folks like.
Have fun,
Jeff
Cascade M37 #1
Cascade M37 #2
Oktava MK012 #1
Oktava MK012 #2
Shure SM57
AKG 414 B/ULS
AT 4047sv
Have fun,
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
- JadeLatrell
Fun. Well, I'll take a stab here, even though going first scares me.
Of course, the usual caveats apply, so I am listening as if I am trying to get a solo acoustic guitar track.
I like the richness and detail of E, the best. But I found that I liked the combination of E and B2, and F and A1. These not adjusted for level, just combined.
A1 and A2 were bright and a bit tinny
B1 and b2 were richer than the A's but a bit emphasised and muddy on the lows.
C was too tinny and brittle on the high end, like the highs were fighting to be heard.
D was mid-rangy and a bit dull because of it
E as stated seemed to have the most detail, though the mid-lows were more pronounced.
F has pronounced mids but I thought the highs were nice but perhaps not enough of them.
This through the Rosetta 800 to Central Station to Adam A7s.
Good luck all.
Good luck all.
MacPro 3.0, 5GB RAM, DP 5.12, BLA modded MOTU Traveler, Rosetta 800, Muse Receptor, UAD-1e, Kore, Komplete 4, Cakewalk Dim Pro, and then some. LaChapell Audio 992 EG (Brimar and Mullard custom tubes), True P2Analog, Sytek MP4A, Adam A7s, MacBook Pro for mobile
- gearboy
Glad that someone finally responded. I posted this over two messageboards! So thanks.JadeLatrell wrote:Fun. Well, I'll take a stab here, even though going first scares me.
Also, experiment with panning A1/A2 and B1/B2 at 9 & 3 and place one of the other mics at 12 o'clock. Obviously there is no wrong way to do this.
I seriously plan on doing this same test through all of my preamps as time allows, so look for more in the future as well as a dedicated webpage. But for now, I can't wait to hear more opinions as I patiently wait to post the... answers?
Jeff
17 meg files at 96 are going to scare most people away. I've seen MP3's posted, which have enough fidelity to compare mics to each other.
The thing about comparing mics is putting them in context. An acoustic guitar sounds really different in a mix than it does solo'd. Same with a vocal, or whatever.
But it's great that you're comparing mics and pres. That's an excellent way to learn about gear. The one test that blew my mind was recording a CD track into DP via the 2408 analog inputs, and then importing that same track into DP directly off the CD into the soundbites window. That's when you discover what your A/D convertors are doing to your sound. (Hello Black Lion Audio - analog upgrade of a 2408 for around $300.)
"Give a man a fish and he will eat for a day. Teach a man to fish and he will wipe out an entire species."
I listened through Peak Pro via headphones out of a Tascam interface clocked to Rosetta 200. Didn't try any mixing of tracks.
A1, A2 - bright, sibilant
B1, B2 - warm, kinda muddy (B2 had more highs)
C - bright, thin (worst on its own)
D - midrangy, yet kinda thin
E - warm, fuller
F - bright, kinda full (probably best on it own?)
I could hear the As working in some rock songs. E and F would work better in folky/singer/songwriter stuff. I guess.
E - warm, fuller
- gearboy
Yeah, but the most scientific that I could do. And remember, this grew out of a demo that I was working on, so it was the way I was recording into DP at the time. When I do the "big test" it'll be 24-bit/44.1kHz and loop-based for comparison in multitrack software.duncan wrote:17 meg files at 96 are going to scare most people away.
Oh, yeah, I agree completely. And obviously mic C or D isn't going to be my first choice for acoustic guitar, but may be cool for something else, etc.The thing about comparing mics is putting them in context. An acoustic guitar sounds really different in a mix than it does solo'd. Same with a vocal, or whatever.
Thanks. Just wanted to share. I'll post the mic list in a little bit.But it's great that you're comparing mics and pres.
Jeff
A1-A2 (panned in stereo) - hyped highs, would cut through a mix
B1-B2 (panned in stereo) - much warmer, full bodied, but not as defined as a
C - lackluster dynamically speaking...clear sound, but not as appealing a tone.
D - prefer it to C, is this the dynamic mic? kinda "rounded" sounding. but i like it. combines with a1 and a2 nicely.
E - full bodied, clean sound
F - well-balanced, my favorite soloed.
combined, i thought the sound of all 8 at the same time was fun.
also combining E or F with D. or a1.a2 with E, F, or D sounded nice to me.
why would i want to skin a cat?
and similar to jadelatrell's as well...except we seem to prefer F over E. i couldn't decide really which i liked better at first, E does capture a certain "trueness" of the instrument, but i found F a bit more flattering and musical.chrispick wrote:Looks like our evaluations in the test are much alike, OldTimey.
-with only one mic over 500, im gonna guess that one of the matched pairs are a pair of mxl 603's, or at least a mic similar in design. studio projects???
Oktavas?
anybody else gonna take a listen?
I started to reader other responses and decided to quit before I developed to many preconceived notions. So...here are my thoughts.
A1/A2 -bright, but not excessively so. Does not appear to accurately capture much low end information. Still quite usable. I think of this as something I would use a texture in a mix. Like when you are more concerned with the click of the pick against the strings than the tone of the instrument.
B1/B2 -much more balanced than A. Sounds fairly nice, but a little unfocused. I also noticed that it seems like there is something going in the sixth measure where the two tracks don't match for a brief moment. Anybody else hearing that. Anyway, this recording could probably stand on its own more than A.
C -Sounds very lo-fi. I'm thinking this is either a dynamic microphone or a very inexspensive condenser. Either way, not (in my opinion) a very usable sound.
D -All mud and midrange and sounds like there is a low pass filter on it. Nevermind, this is my vote for the dynamic mic.
E -This is probably my favorite. Maybe just a touch scooped, but overall sounds very full and natural.
F -A little too mid-forward, but still nice sounding. Seems to be a litttle bit week on the low end. I could see this working well in a busy mix.
Anxiously awaiting results and nervously looking forward to seeing how my perceptions match up with you guys/gals.
-jordan
-jordan
"You must unlearn what you have learned"
-Yoda
-Yoda
- gearboy
Edit: Reposted in original post for this thread.
- gearboy
jmoore wrote:oops
I was just going to respond to you. What information, or did you notice my posting?
Keff
ive never used a 4047. i preferred it to the 414 though. hmm maybe time to check out the AT 40 series! i hear they are great bang for the buck.
i need a good ldc that will sound good on low sources with high SPL's...im too nervous to put my 'flagship' ldc's in front of kick drum, but a 4047 8 inches or so from the kick, might do the trick...
