does dp utilize a dual processor in any way or would a single be just a effective?
thanks
dp utilizes double.J.B. wrote:i'm using dp 4.5 and i am looking to get my mac466mhz g4 tower up to speed with a cpu upgrade and some other things.
thanks
This is probably the most sensible advice.emulatorloo wrote: However at this point I do not think you can justify the cost of an dual G4 upgrade vs purchasing a core duo mac mini or a core 2 duo imac.
You simply will not get the performance out of a dual g4 upgrade for the price you will pay. several years it was a cost effective way to get a boost, but not anymore.
do a search around here for imac or mac mini. The intel core 2 duo consumer machines give a lot of bang for the buck w DP.
do also a search for g4 upgrade. There are several threads on each.
JMHO -- YMMV
dude, those 7448 upgrades are expensive............Don T wrote:Hello,
I'll jump in here. I just upgraded my G4 DA 733Mhz with the Newertech dual 1.7Ghz. It uses the new 7448 processor. I ran extensive speed tests between all of the upgraded G4 towers we have here at school. The DA runs blazing fast. I had 12 VI's running in a project with 70% cpu (buff=512 24bit 44.1khz). The 7448 seems to run read/writes faster as well. Rendering a 1.9GB imovie segment for audio playback in FCP took a mere 2:37. The G5 dual 2.7 Ghz machine took 2:12. The Giga dual 1.33Ghz took 8:19. The Powerlogix dual 1.2 ghz (7455) took 7:07. The Sonnet dual 1.2 (7447) took 4:51. The PL 7455 and Giga 7447 both exhibited a 60% FW slow down when Dp was open (324 card) under OSX 10.4.8 but not under 10.3.9. The Sonnet and the Newertech didn't much care which OS it was running. I estimate that the Newertech and our G5 dual 2.0 run within 10% of each other most of the time. I'm sure under some circumstances the FSB of the G5 will show much better.
On edit: The G3 PL 900mhz rendered the iMovie segment in 7:26
The DA has 1.5GB of CL2 ram, 250GB & 400GB 7200 ATA HD's, FW800 card, motu 424, ATI 9800 pro video card.
FYI
Don
