Motu 828 problem
emadsound
Motu 828 problem
Post by emadsound »
Hi
I have 828 firewier
and OSX platform
univirsal driver 1.4.3
DP 5.2
Appel G5
the problem is i have to turn off - the 828- and on many times to appear in the set up hardware in DP 5.2
and during play back i lost the sound and the DP hang with an error mass. about the hardware (828 )
with the built in audio the DP works fine
some times i hear high beached sound out of 828
can you help me to the cause of the problem ???
thanks alot
kassonica
Post by kassonica »
a couple of things u could try is different firewire lead try a different firewire port as well. Also try resetting the 828 but u'd have to refer to ur manual as i have the 828mk2 and i thinks in different.
hope this helps
best
Purcello
Post by Purcello »
unfortunately, there is no reset on the 828
