trouble with audio pitch on DP4.6
Re: trouble with audio pitch on DP4.6
using 10.3.9 here, dual 1 gig G4, I tried with a newly created project, imported some audio and while the processor seems to be busier i still can't hear any pitch changes in the audio
It's G4/500 MHz with 512 RAM.Any info on what the minimum requirements to run this DSP upgrade in 4.6 are?
The recommend system is a dual G4 and 1 GB of RAM.
Pitch automation works some times and some times not. If I double click in the track in which I am changing the pitch and drag across the section that has been changed I can hear the pitch change but not in regular play back. Can someone explain the proper way to use this feature? Magic Dave? Thanks.
Scott Ruhs
http://www.underpressureband.tk
Yea, pitch automation has so far been really inconsistent. Sometimes it works, sometimes it doesn't. Haven't been able to figure out the pattern yet.
MP 2.93 GHz Quad :: 16 GB RAM :: OS 10.6.2 :: DP 7.11
hmm, how about quantizing the pitch for a track and then bouncing to disk ? would that fix it ?
What exactly are you trying to change ie instrument, voice.
I have a Dual 2G5 and I opened a project that I was working on in 4.52. I copied a portion of a vocal track to a new track, opened the Sequence window, selected pitch from the pulldown menu, waited 30 seconds for the file to analized, then pulled the vocal track up to harmonize with the original. It sounded a little flangy like by itself, but it blended in nicely in the mix. Really cool so far.
Music - http://www.missingpalmerwest.com/Missin ... songs.html
Dual 2.0 G5 (Rev. A), 4.5 GB Ram, Powerbook 1.5 GHZ 1.5 GB Ram, (BLA) 828mkII, UAD-1 X2 , 10.4.8, DP 5.13, Sebatron VMP2000e, Sytek MPA, Many Mics
- sdfalk
Old projects, new it just works for me.
A Metric Halo ULN8-3D…mmmmmmm
Wasn't workng on dual 867 running tiger. is working on 12" powerboook.
I re-downloaded, re-reinstalled(after trashing original 4.6 installation ---> working in real-time everything. Copied to MIDI perfectly. Works very wel.
Peace be unto to you
