Any Caveats about In-The-Box mixing?
Gee, I thought some of those 12 page epics were pretty darn good discussions.ryst wrote:Before this thread turns into another 12 page epic, I thought it would be a good idea to provide you with links to most, if not all, of the other threads from various websites that discuss this very topic.
Except for the "right" one which was utterly ridiculous.
...or should that have been gee sharp?
Hey! I've been doing this for 30 years too. I'm just getting started. Welcome aboard young man!NealF wrote:Lots of good advice here. I'm an oldtimer, too.
Takes a while to change 30 years of habbit.
Oh yeah! Most of them were good. I just figured we could spare the original poster some time. Instead of waiting for the posts to pile up he could start reading the threads where the posts are already piled up.Phil O wrote:Gee, I thought some of those 12 page epics were pretty darn good discussions.ryst wrote:Before this thread turns into another 12 page epic, I thought it would be a good idea to provide you with links to most, if not all, of the other threads from various websites that discuss this very topic.![]()
Except for the "right" one which was utterly ridiculous.![]()
Nathan-
Dual 2.5gig G5, 2.5gig ram, DP 4.6, Live 6, Battery, Kontakt, BFD, DFHS, EWQLSO Gold, Event ASP8's, Trigger Finger, M-Audio 1814, MOTU Fastlane USB, Ibanez MMM1, Schecter Stiletto Studio-5
Polich and Gearboy's advice is good.
Of course, feel free to push levels going through an analog pre. All those tube and/or transformer harmonics are what make them great to use. Just make sure you attenuate the signal prior to A/D into the DP.
To add to what P and G suggested, digital recording is much less forgiving when it comes to dB spiking than analog gear. In fact, inaudible spikes sneak through all the time (you can catch sight of them with fast metering plug-ins like Inspector XL). They can affect dynamic plug-ins (if also digital) and may minimize mix overhead when compounded. So, healthy tracking level overhead is prudent.
That aside, digital recording has far more assets than deficits in my opinion. It's certainly more flexible and editorial-friendly.
In any case, welcome to the fray. Make some music!
Chrispick's referring to "inter-sample peaks".chrispick wrote:... In fact, inaudible spikes sneak through all the time (you can catch sight of them with fast metering plug-ins like Inspector XL). They can affect dynamic plug-ins (if also digital) and may minimize mix overhead when compounded. So, healthy tracking level overhead is prudent.
Think of any frequency above half the sample rate you're using, and you'll be able to visualise this.
Peaks can literally "spike up" between sample representations.
It's obvious, but I'd say cymbals are far more likely candidates than bass guitar as culprits here.
The cumulative effect of having multiple tracks contributing these peaks might in and of themselves well explain what we're talking about.
Easy to do; I'd never heard of this one or seen it in the manual before encountering it on this board last year.denne wrote:sheeesh ... missed that one. thanks jlaudon.jlaudon wrote: Just a handy tip you might know about - press 'w' and lower the master fader, and it will bring all the seperate track levels down the same amount (obviously only before having volume automation enabled on various tracks).
[quote="denne"][quote="jlaudon"] Just a handy tip you might know about - press 'w' and lower the master fader, and it will bring all the seperate track levels down the same amount (obviously only before having volume automation enabled on various tracks).[/quote]
Is there a method to move all the volume automation as well?
I'd like to figure that out - as I have put a master volume set for between -4 to -8dB on all the mixes before sending them out for re-mastering - and there's a lot of automation going on...seems better to skip the master volume entirely (or does it even matter?)
- daniel.sneed
kenoflife, you could just insert a trim plug on masterfader, prefader but post all your other master fader inserts, if any, and set it to your taste : -4 to -8dB.
It would be a conservative change, just enable or disable this trim.
dAn Shakin' all over!
- daniel.sneed
Because of it's 32 bits floating architecture, I can assume there would be no difference at all.
To achieve complete confidence, avoid any non-floating plugin between this trim plug and your master fader.
Maybe someone could clarify the distinction between "not necessary" and "don't do it" when it comes to recording the tracks as hot as possible. The arguments on why is it not necessary in most cases are well understood. But I'm confused by those who say it should not be done.
As long as the tracks don't clip during recording, why is there an advantage to having fewer bits filled? If you record 30 tracks, all as hot as possible, but with no clipping, and then need headroom for the mix and plugs, you can pull the faders down on the original tracks. It may be unlikely that you really need the extra resolution, but it's there if you do.
That's a really good question. One to which I have yet to hear a really good answer.bayswater wrote:As long as the tracks don't clip during recording, why is there an advantage to having fewer bits filled?
Certainly your front end needs to be taken into consideration. For example, if your system sounds best when DP's meters are peaking at -12db, is that because of something going on at the DAW or something going on at the analog end of things? Which brings up the whole issue of calibration.
Lots of questions, not too many answers. Sorry.
