Playback over Laptop speakers
DeafMute
Post by DeafMute »
This may sound quite odd, but does anybody know if i can playback my Traveler's main outs through my macbook speakers?
To me it seems quite logical. lf I'm doing field recording, I wouldn't want to carry a pair of speakers with me, I'd also avoid using headphones if i wanted to share the recordings with a group.
The only thing i can think of, is to route the main outs and plug them straight into the macbooks input (the microphone input) I haven't tried this yet, since it seems rather scary.
I'm running a Traveler witha Macbook Pro and DP 5.1.
Any suggestions?
PePe.
Flash Focus Record.
Mac Book Pro 2.16 Ghz - 2GB RAM. OS 10.5.7
Black Lion modded Projectmix. MOTU Traveler
Digital Performer 5.13
Wurlitzer 200 Piano
DeArmond Archtop X-155 Guitar
Just set your "Default Output" to "Built-in Audio" on the Audio MIDI Setup utility. I use Audio MIDI setup so often that I keep it on my dock.
DeafMute
Post by DeafMute »
Thanks cuttime, even though that was my first guess, i did it again as per your suggestion and i still can't hear a thing. Would i have to change any setting within my Traveler?
I changed both (separately) my Default and my System outputs.
Cheers
PePe.
Flash Focus Record.
Wurlitzer 200 Piano
Leave the system audio on "Traveler", and make sure that the DP playback bundle is set to "Built-In Audio".
DeafMute
Post by DeafMute »
This worked indirectly. By not plugging in my Traveler, I got the pop-up, when starting up DP, to set up the I/O‘s, I chose built-in, and there it was...
Thanks cuttime
PePe.
Flash Focus Record.
Wurlitzer 200 Piano
You can leave the Traveler plugged in, just select Built In Audio from the Hardware Driver window.
DeafMute
Post by DeafMute »
I guess i wasn't clear enough. I figured it out when I did not plug the Traveler , and i was ale to take it from there on to plugging it and getting playback over my Traveler outs and my Mac speakers.
PePe.
Flash Focus Record.
Wurlitzer 200 Piano
