Funny you should mention it. I also am getting audio bursts. They are sporadic and seem to come at random times in my sequences. I think you are correct about them having to do with event chasing; I recently turned it on, and it seems that maybe they didn't happen before then.Frodo wrote:Just today, I started noticing audio bursts with VIs
Thanks for your reply. Glad to know someone more knowlegable than me is on the case.Frodo wrote: But the audio leakage is quite real.
I'm not sure you really want to know. In fact, I rather envy the notion that you've not experienced this. Consider yourself blessed!!waxman wrote:Please explain audio leakage?
No distraction at all, Nicky. For all my previous verbage, I'm rather stumped, actually. Gladly, it's not become a crippling issue by any means. I'm currently just preparing a series of orchestral scores for porting into Finale, but projects slated for summer will be much more critical where audio mixing and presentation will be mission-critical. I'll have to start in on running QT movies as well.monkey man wrote:Hey, Fwoggy!
Thanks for those thoughts.
The "volume increase and phasing" bursts I experienced appeared to emanate from within DP's mixing engine, as I no longer mix OTB, running the ROMplers directly into aux tracks.
This, coupled with the uncanny circumstantial similarities, is why I asked again.
Thank you again for allowing the monkey to distract you from your mission.
Nicky
Yup, it does seem to be the full mix that rises in volume for a second or so.Frodo wrote:DP's mixing engine, eh? Funny- I've not put in any mixing automations at all, so if this is indeed the case then the solution is fairly beyond reach. If master volume levels are doing an internal trampoline act not represented in the GUI, I'm not quite sure quite what to do-- and the bursts appear to be occurring (shire-side) with *all* instruments as opposed to individual ones. Is this similar to your experience?monkey man wrote:Hey, Fwoggy!
Nicky
A surf of the Logic boards (!) could yield less pain.Frodo wrote:If it is indeed DP's mixing engine I am actually considering installing Logic on my MacPro just for the sake of comparison. If it happens with Logic as well, then that means it's an AU/OSX issue.
Agreed.Frodo wrote:A better comparison would be to use another non-Apple DAW, but this is more trouble than its worth, me-thinks.
