a little bit of 5.12 MIDI? weirdness?
kgdrum
Post by kgdrum »
well yesterday,I had some strange developments w/ 5.12.if I open the project I am working on (don't play it)after 5-10 minutes a a MIDI loop that sounds like the click track(w/ MIDI induced echo) keeps popping up.weird?if I hit the panic button on my mico express it would not stop! I changed the tempo to see if it would follow the tempo(it did) and then it faded away after I reset the tempo,......this happened 3-4 times any ideas? :roll:
thanks in advance
KG
Timeline
Post by Timeline »
I wonder if my experiences are related? When I first loaded a file I got chunk load error. .12 obviously reloads sessions using chunks. That must be where errors would occurs if they do.
After reopening a couple of times the problem vanished. Maybe they are booking errors somewhere and processing them on re-opens of the same files.
Try reloading a couple of times and see what happens.
kgdrum
Post by kgdrum »
hi Gary-thanks for the reply-do you mean quit DP and startup project again?if so I will give it a shot .thanks KG
