Calibration Plugin?
thermos
Calibration Plugin?
Post by thermos »
Anyone know of a freeware calibration plug thats better than the one that omes with DP? Like one that does, white noise, specific frequencies, etc?
Did a search, couldn't find any.
thanks
vier-personen
Post by vier-personen »
I use http://mda-vst.com/
they have free AU plugins (UB), one of them is called TestTone - Signal generator with pink and white noise, 1/3 octaves and sweeps
you have to insert it in an audio track and enable input monitoring (I write this because it took me some time to figure it out ; )
DP 5.12/OS X 10.4.9/MacBook C2D 2.0 1GB Ram/RME Fireface 400
grimepoch
Post by grimepoch »
What are you trying to calibrate?
[MacPro-4x2.66/7G/OSX10.5.2 - 2x896HD - ADA8000 - Lucid Genx6 - DP5.13 - Logic 8.02 - 2xUAD1e - ExpressXT - Mach5 - MX4 - Korg LegD - impOSCar - Battery3 - uTonic - Rapture - DimPro - Vanguard - Reaktor5 - Absynth4 - FM8 - Pro53 - Vokator - Waldorf Ed - Addictive Drums - Melodyne - Ultra Analog - Zebra2 - WaveArts - - Altiverb - Etc. ]
[Virus TI - Virus B - Waldorf Q - Waldorf uwXT - Supernova II - Nord Rack 3 - JP8080 - XV5080 - Fantom X7 - Triton Rack - Pro/cussion]
Siryne
Post by Siryne »
Audio Ease makes a free program called "Make A Test Tone" you can find it at: http://www.audioease.com/Pages/Free/MATTMain.html
Mac Pro Quad "Nehalem" Xeon 2.93 Ghz-12GB RAM - OS 10.6.4-DP 7.21- & Logic 9.1.3 - MOTU 896HD- Apogee Big Ben-Tascam US2400-UAD2 Duo-Altiverb 6-Melodyne Editor-Autotune Evo-Plugins from UAD, URS, PSP, Abbey Road, Flux-VI's- LASS-EWQLSO-VSL-Kirk Hunter VS Pro-Kontakt 4 -Manley Voxbox, Brauner VM1, Soundelux E47C & much more.
thermos
Post by thermos »
Thanks for the replies. Yeah, the mda vst one is working great. Don't even THINK of trying to use the au versions, one instance will send your cpu off the handle.
I'm calibrating my Portico compessor to get the levels to match and the unlinked compression to be the same.
grimepoch
Post by grimepoch »
gotcha...cool.
oldguitars
Post by oldguitars »
make a test tone is not free, but it is good. It is a stand alone and it works great....
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
gearboy
Post by gearboy »
thermos wrote:Thanks for the replies. Yeah, the mda vst one is working great. Don't even THINK of trying to use the au versions, one instance will send your cpu off the handle.
Why?
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
chamelion
Post by chamelion »
One of the world's best-kept secrets would have to be Audacity. Audacity is free, open source software for recording and editing sounds. It is available for Mac OS X, Microsoft Windows, GNU/Linux, and other operating systems. It provides a handy test tone feature that I've found useful and reliable.
Geoff
"Don't worry,
be hoppy!"
vier-personen
you use a vst-wrapper and it‘s still less cpu demanding than the au version? I don‘t have the wrapper and it never occured to me that the mda au plugs are heavy on the cpu...
how do you like the portico?
thermos
Post by thermos »
Thanks for the audacity tip!
Yes, for some reason when I tried using the au versions of the mda (test tone and rephsycho!) they...
A: Didn't work properly,
and B: made my dual G5 cpu bounce up to 100%.
The vsts through the wrapper work way better, though are visually buggy.
Oddeo
Post by Oddeo »
somewhat on the same tip.....I have a pair of Behringer Trush B2031A monitors, they sound great.....but! My studio is set up in a fairly small room. I have the monitors on monitor stands, they are about 2-3 feet from my face and are almost right up against the wall. I know that this is not the preferable setup, but it is how I have to do it at this time. The bass freqs hit about 5 feet back from me. Though I have some fairly nice monitors I end up using my headphones for the mix a lot of the time. Any suggestions on how I can calabrate my set up so that the monitors give me a more true sound where I am sitting?
Thank you,
Neil
______________________________________
DP 5.11/ G4 1.5 1G RAM / Korg Triton Studio / Roland Juno 106 / Fusion 6HD/MC-303/ TC Electronics Powercore / Tascam FW-1884/ Battery2 / Kompakt / Intakt / EWQL Symphonic Orchestra / NI Express Keys / Korg PadKontrol / tons of other random guitars, drums, gear and software
grimepoch
Post by grimepoch »
Get a copy of Fuzzmeasure and an unity gain mic (behringer makes one). I use this with a digital EQ between the output of my 896 and the monitors (well I did when I was using monitors that needed EQing). I used the Behringer DEQ2496 as it is not supposed to introduce phase delays (it's a digital piece). By doing this I was able to really balance out the monitors.
As for bass, I bought a sub. For awhile, I just used a run of the mill Sony one, but eventually got a TS-10 from Tannoy.
Phil O
Post by Phil O »
grimepoch wrote:As for bass, I bought a sub. For awhile, I just used a run of the mill Sony one, but eventually got a TS-10 from Tannoy.
Was it you who recently got some Adam A7s? Are you using the TS-10 with the Adams? How's it working out?
Or am I confusing you with someone else? :oops:
Phil O
Post by Phil O »
oldguitars wrote:make a test tone is not free, but it is good. It is a stand alone and it works great....
I know I downloaded a free version of that at one point, but when I went back to the site to check for updates I couldn't find a freebie. Did they discontinue the free version?
