Converting old audio cassettes
mjl660
Post by mjl660 »
Does anyone have a quick way, (with reasonable qualtiy) to convert old audio from cassette tapes? I have some old band tapes from the mid-late 80's that I would like to convert to digital before they degrade any further. I've inputed the audio from one tape years ago through my Mackie 1604 VLZ Pro mixer into DP, but it took so long and with my old machine it was crashing. I would like the ability to EQ things as well. I also have a stand alone componet VHS to DVD converter (cheap one, Lite-On brand LVC9006) that has RCA audio inputs on the front. Would it be easier to convert it to digital first this way, then import the file to DP? I.m using an old Mac G400 (yeah, I know...upgrading soon to either a Mac Pro or and old G5 as I still would like to use Mach five), DP 4.12, and a Motu 828 mkII. Any sugestions would be greatly appreciated.
Thanks,
Post by Shooshie »
I don't know of a tape player with a USB output, if that's what you mean, though it wouldn't surprise me if one exists. All I know is to record it the way you would any other hardware device in your rack. Route the outputs to your audio interface; record with DP or your favorite DAW.
mjl660
Post by mjl660 »
Thanks Shooshie. I'll give it a try. I'll just run the L & R RCA audio out from the cassette deck split to a 1/4" stereo jack into my Motu 828's input and see how DP handles it. If my G4 400mhz chokes on all the audio, I'll wait until I purchase a Mac Pro xeon dual 2.66.
Thanks again
Pappy725
Post by Pappy725 »
I don't think a stereo plug will work going into your 828. I would run separate line for each channel and link the two tracks you record to as a stereo pair.
Stephen
emulatorloo
Post by emulatorloo »
mjl660 wrote:Thanks Shooshie. I'll give it a try. I'll just run the L & R RCA audio out from the cassette deck split to a 1/4" stereo jack into my Motu 828's input and see how DP handles it. If my G4 400mhz chokes on all the audio, I'll wait until I purchase a Mac Pro xeon dual 2.66.
Thanks again
In case you have Adaptec Toast (A lot of people round here have that CD Recording software) it comes with a little app to record and enhance records and cassettes. Called CD Spin Doctor. Worth looking at for this application if you already have it lying around.
BTW A google produced this odd device for PC's
http://www.meritline.com/meritline-digi ... sette.html
npatton
Post by npatton »
Spin Doctor's great. I've converted a few items to CD with some nice results. Even took a VHS of a rehearsal for a show I was creating with some actors, routed it to Spin Doctor, split it into tracks and burned a CD in Toast from it. I did have to import it into DP to do some EQ surgery on it, but it was a usable result for their future pianist to have a guide.
n
BTW, at the time using a Single 1gHz G4. Just needed some HD real estate to handle the large file.
Mac Pro (Late 2013) (3.5 GHz 6-Core Intel Xeon E5, 32 GB RAM) OS 10.13.6
MacBook Pro (2 GHz Intel Core i7, 8 gigs RAM); OSX10.11.6; DP 10.13; Unisyn 2.1.1; Stylus RMX; MOTU MIDI Express XT; MOTU 828x; Kurzweil PC3 with Kore 64; Roland XV-5050, D-50; Alesis QS7; Yamaha S90ES, TX-216; Hammond XK-3
FWIW, my own music can be heard at...
http://www.neilpatton.net
http://http://www.pandora.com/neil-patton
Business Site: http://www.pattonmusic.com
rockitcity
Post by rockitcity »
mjl660 wrote:... I'll just run the L & R RCA audio out from the cassette deck split to a 1/4" stereo jack into my Motu 828's input and see how DP handles it. If my G4 400mhz chokes on all the audio, I'll wait until I purchase a Mac Pro xeon dual 2.66...
828 does not have a stereo input. use individual channels as previously mentioned.
Recording stereo audio into your system should be no problem. Just make sure you have your input trims on your 828 set properly. This will most likely be -10 for a consumer cassette deck. Just get a clean recording going in and manipulate the audio to your taste after you have captured it. I wouldn't do any thing other than setting level going in. Just make sure you have the right EQ and Dolby NR settings on your cassette deck on playback.
Mac Mini Quad i7 2.6 Ghz, 16 G RAM, 2 SSD's. Motu 896 HD Hybrid, 8pre, Fastlane USB, Presonus Faderport, vintage guitars!
