Best way to merge two tracks???
cjswitzer
Post by cjswitzer »
I'm looking to burn a cd that has two tracks blended together. I'm basically looking to to have say track 3 go into track 4 with no noticeable transition between them. Any and all suggestions welcome. Thanks in advance!
Dwetmaster
Post by Dwetmaster »
That's done in your burning software where you tell it no gap between songs. Then if you cut your soundbites exactly where it should in DP then it should be played correctly on your cd. To be sure, your cut should be at a zero crossing...
glsimonsen
Post by glsimonsen »
just hi-lite both tracks, bounce to disk, import in iTunes and burn.
the degree to which they'll blend together depends upon how they were recorded and what effects are on each track, etc.
Dwetmaster
Hey cjswitzer
But do you want them to be seen on the CD as track 3 only or as track 3 and track 4?
Lucid
Post by Lucid »
I want it to show up as track 3 and 4.
So as far as recording an album, do most of you usually record all the tracks in one project or do you create a new project for each song. I usually create a new project for each song to keep the file sizes to a min. I think that's why I have found it more difficult to blend two songs together...
Dual 2.5Ghz G5, 3 Gigs mem, motu 24i/o, DP5.11
JadeLatrell
Post by JadeLatrell »
I might be way off here, but this sounds like a good time to use chunks or sequences.
Again, I'm no chunk expert yet, its just an often overlooked little piece of genius in DP.
MacPro 3.0, 5GB RAM, DP 5.12, BLA modded MOTU Traveler, Rosetta 800, Muse Receptor, UAD-1e, Kore, Komplete 4, Cakewalk Dim Pro, and then some. LaChapell Audio 992 EG (Brimar and Mullard custom tubes), True P2Analog, Sytek MP4A, Adam A7s, MacBook Pro for mobile
Lucid
Post by Lucid »
You could very well be correct on this JadeLatrell. I also have not used chunks or sequences often in DP yet. Sounds like I need to hit the DP manual again. Thanks!
Dwetmaster
Chunks Rules man and especially for that. You can put your master fader and all of your fx in a VRACK so that everything is processed the same way. If you want to keeep your file size to the minimum, you can do all of your editing/recording in separate projects and then import all the songs in a single project making sure that you check the "load soundbites from selected chunk only". That way you only import whats useful and you keep out your junk. Then it's easy to go from one song to another for mixing comparison.
soloquest
Post by soloquest »
Lucid wrote:I also have not used chunks or sequences often in DP yet. Sounds like I need to hit the DP manual again. Thanks!
Me too. Can someone please give an explaination of "chunks"? What is it, how it is used? I thought it was just for MIDI data, and I don't record much MIDI stuff.
As bad as I am, I'm proud of the fact that I'm worse than I seem
FLOYDWEB.COM
Dwetmaster
There is already a lot of chunks Thread.
