Multiple 828 output problems HELP !
jjwonk
Post by jjwonk »
I am using 3 (original) 828 interfaces in my rig thru a firewire hub. (Just added the third one). Before the additional 828, I had no problem with input and output assignments when fed to my 3204 Mackie board. The first 828 played back thru channels 1-8, the second 828 played back thru channels 9-16. Since I added the third 828 and routed "another bank" of playback thru channels 17-24, the outputs are not playing back thru the assigned channels. For example 828-1's output assignments are playing back thru 828-3's outputs. I have all the outputs in DP assigned properly. The cabling from the interfaces are routed correctly. I removed all other firewire devices from the firewire hub. The Mackie board assignments are correct. I have designated 828-1 as the master interface. I suspect I have something wrong configured in the Audio-MIDI setup, or on the configure hardware driver settings. I'm hoping someone can tell me what the problem might be.
Thanks Jay
Imac 2.0 G5 OSX 10.4.9 1 gig RAM/External Firewire Hard Drive
DP 4.6.1
nick danger
Post by nick danger »
Not sure what your problem is, but you might be able to connect one of your 828's to the "master" 828 via ADAT and see if that helps-- you may be overloading your firewire bus?
jjwonk
Post by jjwonk »
Thanks I'll try that. Would like to know if anyone has experienced this using 3 828's via firewire hub. Take one 828 out of the chain and it's fine. Checked all the hub inputs too, all working good.
2019 IMac , Digital Performer 10.11, MOTU 828 ES Interface
nick danger
You should check motu's website, but I think they recommend using a timepiece (http://www.motu.com/products/MIDI/) if you are using more than two 828's.
jjwonk
Post by jjwonk »
Still baffled by this problem. Can't understand why all the playback outputs are not playing thru the assigned channels on my mixing board.
Motu 828-1 outputs are playing back thru channels 17-24 on the mixer (even though they are wired to play thru channels 1-8)
Motu 828-2 outputs are playing thru channels 1-8 on the mixer (even though they are wired to play thru channels 9-16)
Motu 828-3 outputs are playing back thru channels 9-16 on the mixer (even though they are wired to play back thru channels 17-24 on the mixer)
I have designated Motu 828-1 as the master. All 3 interfaces show up in the hardware configuration menu and are selected.
Am I doing something wrong in the audio setup perhaps ?
I have searched in vain to find a similar problem and cannot find anyone who has experienced this odd occurence. Since they all are working properly, I suspect I have something set wrong in DP4.6 or audio setup.
Still could use some suggestions or help. Thanks.
