Recording multitrack audio to esata vs. firewire 800
Perhaps this has been covered but according to the specs. esata should be much better than firewire 800. Are people moving over to esata drives for recording? I've had no problems with firewire 800 so I don't know if I should follow the "if it ain't broke" axiom or not.
OS 10.4.8/DP5.11/MacbookPro/2gig ram/G5 dual 1.8/4 gig ram (10.3.9)/Kontakt2,Stylus RMX,Native Instruments,Pluggo,Altiverb, fw 800 drives, Yamaha 01V,01X,02R,etc...
- Dwetmaster
True Dat.
But If you experience any bottleneck, then Esata Rules!!!
- Dwetmaster
You need a express card port on your laptop and a express card to Esata adaptor. you connect your esata to it.
Agreed-- if it ain't broke, let it be.
Mine was "seriously broke", so I had no other choice but to go eSATA with a host card.
FWIW, if you plug a FW400 device while an FW800 device is connected, all devices will run no faster than 400.
If FW is working for you-- rejoice!!
Mine was "seriously broke", so I had no other choice but to go eSATA with a host card. There *are* also FW host cards, should that option ever be needed.
Just avoid USB 2.0 for audio recording/streaming.
- Eleventh Hour Sound
Yeah, eSata feels faster and more responsive... If you've used all the internal drive slots you can add an eSata PCIe card. I got the big Sonnet card at the time, but now I think they have a more affordable card. And if you have a drive enclosure and card that supports port multiplication you can run several drives (up to 5 I think) on one port....
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
- Mr_Clifford
Frodo, does that include running a FW800 drive off a FW800 PCI card (like the Lacie one I bought for my G4) whilst running a FW400 audio interface off the computers built-in FW400 port?Frodo wrote:FWIW, if you plug a FW400 device while an FW800 device is connected, all devices will run no faster than 400.
It's probably a bit academic as, from what I understand, you only really start to get benefits from FW800 when running several Hard-drives (or devices).
Mr C:Mr_Clifford wrote:Frodo, does that include running a FW800 drive off a FW800 PCI card (like the Lacie one I bought for my G4) whilst running a FW400 audio interface off the computers built-in FW400 port?Frodo wrote:FWIW, if you plug a FW400 device while an FW800 device is connected, all devices will run no faster than 400.
To the best of my knowledge, no. With the Mac, all the built in FW ports (400 and 800) funnel into the same bus and as a result reduce the Mb/s transfer rate. Once you add another bus, the bandwidth is independent-- so 800 stays 800.
However, there may be some spec on particular cards where multiple inputs are allowed and the bandwidth of the PCI (e or x) bus is likewise shared by all devices connected to the card. The good news here is that transfer rates on PCI e/x hosts are quite accommodating.
In most cases, specs I've read on host cards cite transfer rates per port. As long as that number is equal to or above the transfer capabilities of the drive connected to it, all should be fine.
FYI-- according to my online bits and bytes calculator:
http://www.speedguide.net/conversion.php
Firewire 800 cards: 800 Mbits per second (or 95 Mbytes/sec)
eSATA II cards: 300 Mbytes per second
It is possible, but the protocols are not necessarily universal-- and that means there is a big risk of incompatibility. It's not nearly as plug-and-play as it might seem.PaganGods wrote:what about gigabit ethernet for audio recording? That should be even faster than FW800, but not as fast as SATA. Any reason not to put an ethernet port to use in the studio?
Gibson uses their own Magic protocol, Fostex uses Netcira, and so on.
Axia Livewire is among the leaders in broadcast audio over ethernet, BUT-- a lot of these protocols are for Windows and PC. Digigram Ethersound is one of the exceptions that posts OSX drivers.
A reason NOT to use audio over ethernet is a very good question-- and it also begs the question why it's not discussed more. Audio has to be "processed" somewhere before it is passed. Wherever it's processed, that device would first need an ethernet port, which is not always standard on any but the more expensive devices.
To be honest, I'm not sure how this could be set up reliably without a very large cash outlay.
But one thing about FW, for example, is that FW is a point-to-point protocol and relies less on the CPU than USB 2.0. These formats/protocols haven't been promoted or embraced by MOTU for use with DP to the best of knowledge.
Honestly, I'd like to learn more about how all this is done.
