Below are screen grabs of trumpet sounds (from my first playback sampler, 1989) triggered by MIDI notes in DP. The notes would play immediately when triggered by MIDI as they also do when I click on the Mach 5 keyboard. I don't have any issues with how they respond when triggered.
However, there does some to be some initial breath noise ( or ghosts in the machine???) before the beef (not a musical term is it?) appears. (I usually truncate percussive sounds right at the point of...beef.)
Should I leave well enough alone and go have lunch???
Or should I roll up my sleeves and start truncating???
2017 2.9 GHz MPB/1TB ssd; loaded 2012 i7 quadcore Mini, OS 10.15.5 DP 10.11, Logic 10.5.1, Silverface Apollo Quad/TB, K12UC, Falcon, Integra 7, MIDI guitars etc.
for myself. I'd get rid of the breath noises, as it is unrealistic to take a breath every note (unless you're heavy smoker like myself ), however, I'd capture at least of the breath noises and put them on a couple of the high out-of-instrument-range keys to use spareingly for effect.
