Mac OS X 10.4.9
borjam
Post by borjam »
I've been looking at the kernel extensions and frameworks, and one of the frameworks has been updated: FWAUserLib
The documentation is here
And, in short it's the system service that allows applications to do things such as creating isochronous audio streams over Firewire.
Apogee Ensemble users, time to test :)
Is that the gentle roasting of Guinea Pigs I smell?
Braised rodent nuts, perhaps?
Smouldering Guinea brains?
Damn the culinary consequences; if it's snappy, I'm in :lol:
Doh! There's that 2 week download time to consider.
Better start now....
By the time I'm done, there'll be Unicorn stew on the menu! :lol:
wheever
Post by wheever »
borjam wrote:I've been looking at the kernel extensions and frameworks, and one of the frameworks has been updated: FWAUserLib
Neat! I wonder if this will positively impact my Firestudio's niggling FW issues. (loss of clock on sleep...some other stuff.) Or my Novation SL's habit of crashing CoreMidi...
One can only hope, I suppose.
Andrew
Performer user since--HOLY CR*P--1986? YIKES!
Eleventh Hour Sound
Post by Eleventh Hour Sound »
(Backuping up and running TechTool Pro before I take the leap) :D
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
Eleventh Hour Sound
I looked at that document and saw some commands that some software manufacturers seems to use a lot:
FWADisposeFWAudioDevice
Destroys an audio device object.
FWADisposeFWAudioEngine
Destroys an audio engine object.
FWADisposeFWAudioMIDIPlug
Destroys a MIDI plug object.
FWADisposeFWAudioMIDIStream
Destroys a MIDI stream.
FWADisposeFWAudioStream
Destroys an audio stream object.
FWADisposeIsochStream
Destroys the isochronous stream reference.
FWADisposeMIDIStream
Destroys a MIDI stream reference.
:D
RecordingArts wrote:(Backuping up and running TechTool Pro before I take the leap) :D
Brave boy. Godspeed, and TIA, RA. :wink:
Eleventh Hour Sound
After the prep of backing up, running TechTool Pro 4.52, Apple's Disk utility to repair disk and permissions I took the leap...
I ran the updater, after it finished updating it required a restart. (I think it rebooted twice automatically)... I repaired permissions.
(Remembered that I had Dashboard disabled (to save resources) so I enabled it and re-ran the updater rebooted, repaired permissions again )
Launched DP 5.11 and...........
So far So Good! :D
Of course I may not discover if anything's broken right away but so far so good!
What I'm hoping was fixed:
I was having an issue where certain situations would kill audio output completely... Usually when I was running Antares AVOX, but sometimes switching presets on MX-4 during playback would cause it... I would hear a small pop and then loose audio until I went to hardware setup. This would happen regardless of the buffer settings and sometimes without clipping the performance meter too! (I'm using a Tascam FW-1082 FireWire interface) also, before the update, my BFD output assignments in the instruments windows under bundles would get lost and switch over to Ableton Live...
We'll see if the update helps anything :D
Last edited by Eleventh Hour Sound on Wed Mar 14, 2007 11:15 am, edited 2 times in total.
sdfalk
Post by sdfalk »
Exporting to mp4 STILL doesn't seem to work.
A small thing, but annoying.
Bowman
Post by Bowman »
I just downloaded 10.4.9 and Itunes whatver and all my A/V stuff seems to be working fine.
And Quicktime exports to mp4 just fine.
iMac Intel Core i5 3.2ghz - 16gb RAM - OSX 10.10.5 - DP 9.01 - Mach Five 3.2.1 - Ethno Instrument 2.0.3 - Kontakt 5.4.3 - 4pre - 828 original - micro express
chrispick
Post by chrispick »
ransomhskr wrote:
waxman wrote:What••™s New in this Version
The 10.4.9 Update is recommended for PowerPC and Intel-based Mac computers currently running Mac OS X Tiger versions 10.4.0 through 10.4.7 ...
i have 10.4.8... i wonder if my version is "fixed"...?
It's recommended for 10.4.8. From my Software Update screen:
  • "The 10.4.9 Update is recommended for PowerPC and Intel-based Mac computers currently running Mac OS X Tiger version 10.4.8 and includes general operating system fixes, as well as specific fixes or compatibility updates for the following applications and technologies: blah, blah."
I've loaded it on my box and have been working in DP for a little while. Seems cool.
sdfalk
Post by sdfalk »
Bowman wrote:I just downloaded 10.4.9 and Itunes whatver and all my A/V stuff seems to be working fine.
So what..that's not the point
If it's offered as an export option in DP, it should be working
Frodo
Post by Frodo »
sdfalk wrote: If it's offered as an export option in DP, it should be working
Is there some version or some special component of LAME that needs to be installed to do mp4 export? I was thrilled just to get the mp3 export working.
sdfalk
Post by sdfalk »
As I understood it (and I may be wrong) quicktime was the underlying
engine for mp4 export.
Tritonemusic
Post by Tritonemusic »
sdfalk wrote: As I understood it (and I may be wrong) quicktime was the underlying
Hey S,
Which version of Quicktime are you using? I'm still on 7.1.3 and OS 10.4.8 so, I haven't been able to try it out in DP yet. I'm just curious...
Anyone have any preferences about the combo updater vs. Software Update?
