AU plugins don't display in 5.11
mulletsaison
Post by mulletsaison »
When I select any of my AU plugins or instruments, the header of the plugin/instrument window shows up, but the actual plugin/instrument window does not. The preset menu is populated correctly, it's just the graphics just don't show.
Any advice?
Thanks in advance.
Yiannis
Post by Yiannis »
Try to trash the preferences and let Dp scan the AU again :wink:
I am a very happy DAD.
MacPro 3.33Ghz 6core-32g Ram-10T HDs-10.12.6-Dp-10.0.1.
Korg Kronos 2-Korg Pa4X-Ensonic TS 10-Korg T3-Yamaha Dx 7iiFD-Akai S3000xl-Roland JV 2080
Genelec 1031A with KRK 10S sub-Yamaha NS10m
ULN-2..Tubetech Lca2B-Avalon 737sp-HEDD 192-Lexicon PCM 90.
Soundcraft Sapphyre 28ch
mulletsaison
Yiannis wrote:Try to trash the preferences and let Dp scan the AU again :wink:
Didn't change the behavior unfortunately, thanks for the help, though. Now at least I know where those preferences are.
David Polich
Post by David Polich »
I know it sounds silly, but are you sure your audio interface is switched on and your Mac recognizes it in Core Audio?
emulatorloo
Re: AU plugins don't display in 5.11
Post by emulatorloo »
mulletsaison wrote:When I select any of my AU plugins or instruments, the header of the plugin/instrument window shows up, but the actual plugin/instrument window does not. The preset menu is populated correctly, it's just the graphics just don't show.
Any advice?
Thanks in advance.
We just went thru this one not too long ago. I will see if I can find the thread.
At anyrate, you need to set the output assignment of your VI to the sound card/audio interface you are using (that is what sound card/audio interface it is going to play thru). Once it knows that, then it will load.
See where I have assigned my audio to my Delta RBUS 1-2? You need to do the same for your VI. Then it will open and show you the graphics.
Best of luck
Here is that recent thread:
http://www.motunation.com/forum/viewtopic.php?t=18377
Look down at magicdave's post. beginning with "Check the Output Assignment for the Instrument Track in the Tracks Window."
Noam
Post by Noam »
also make sure that mono plugs and inst.s are assigned to mono outputs / stereo to stereo outputs -
MacbookPro Core 2 Duo 2.33/2gig mem.
M-audio Projectmix, Behringer ada8000, DP5.11 and a rash of bargain condenser mic.s
fogtone.com - Tornotics music
