Axiom 49 -> DP5 VI lag
kbmh
Post by kbmh »
Just got an Axiom 49 (affordable, wanted faders, knobs, pads,
etc.) and was trying it with DP5 VI's and there's a considerable
lag in response time. Tried lowering the buffer to as low as it
can go and Use CoreMIDI patch-thru is set in the Preferences
but it's still slow. Using a MacBook 2Ghz with 2G of RAM.
Am I missing something? (guessing the answer is a resounding
YES!)
jmguru
Post by jmguru »
Hi, I just bought the Axiom 25 and I had the same problem.
Do you have the USB and MIDI in/out cables connected ? I also noticed I was generating double notes because I had them both hooked up. I disconnected the MIDI cables and I just have MIDI through USB. No lag or double notes ,now.
I'm not sure if thats you're case, but stated just in case.
iMac 2Ghz/3GB, MOTU 828mkII - Microlite, Access Virus Classic + analog synths + pots n pans
chrispick
Post by chrispick »
Yeah, just go USB. I have the 61 and it's working great for me that way.
Bjoillsing
Post by Bjoillsing »
Hmm I just bought a Axiom 25 and it works perfect not much lag (I'm using it for live playing), and at this moment I use my MacBook internal soundinterface and the axiom is connected to it via USB...
I use it with DP 5.11 as host for Reason 3 and I also use NI's B4 and Absynth.
Got buffer set at 64...
MacBook Core Duo 2.0 gHz 2 gb ram, Ultralite, DP 5
caesparza
MIDI - USB?
Post by caesparza »
Hi, I'm just new here... I'm sorry if this question seems a litle bit dumb... :oops:
I just have a question, right now I have an axiom 49 conected to the ultralite MIDI in/out ports, when you talk about USB connection, are you talking about direct Desktop or Laptop connection??
Thanks in advance.
CE
