Hey there,
First off, my apologies for posting this in the Mac forum, but I wasn't sure where else to post this.
I currently own a BLA modified Traveler and recently acquired a Mackie HDR 24/96. Currently, the HDR has three of the Apogee digital I/O cards. I want to use the ADAT outs of the Traveler to record into the Mackie so that I don't have to bring a computer out to remote gigs. The problem is that I can't seem to get the signal into the Mackie. I've tried a ton of settings and am truly stumped by this.
Does anyone know how to properly accomplish this?
MOTU traveler and Mackie HDR 24/96 issue
Hello,
It is easiest to use the CueMix console to set it up but you can also do it via the front panel. You should use CueMix console first to better visualize the matrix.
Make sure the Optical ports are set for Adat.
In CueMix Console, select Bus 1 tab, assign this bus to Adat 1-2 (RH side). Turn up Bus Fader to max.
Turn up the faders for Analog 1-2. Make sure all other input faders are down.
Set pan for Analog 1 hard left, Analog 2 hard right.
Select the Bus 2 tab. Assign to Adat 3-4 and bus level = max.
Turn up faders Analog 3-4, all other inputs down. Set hard pan so Analog 3=L, Analog 4=R.
Bus 3 assign to Adat 5-6, bus level = max, turn up faders 5-6, set pan.
Bus 4 assign to Adat 7-8, bus level = max, turn up faders 7-8, set pan.
When you are happy with the mix, I would save this as a preset.
Hope this helps.
--Paul
Hope this helps.
--Paul
