Looking for Radio simulation plugin
jlaudon
Post by jlaudon »
Hi
I'm looking for some kind of plugin that can simulate an old radio sound (voice, music), or a way to do this with existung eqs, etc.
Can anyone pls. enlighten me?
thanks
MacBook Pro 2021 (M1 Ultra) with 64 gigs RAM. DP 11.23
Frodo
Post by Frodo »
Start by taking out everything below 400Hz, and then reducing everything above 2Khz. Then, if you have the option, make a narrow bandwidth notch of about +4-6db at 500Hz.
If you've got a good compressor, add it as well. You want to start compressing early, at around -20db, with a ratio of at least 4:1.
That will sort of give you a telephone effect, raise the threshold of the compressor (or remove it altogether) for more of an AM radio effect.
I don't think you need to buy anything special for this. In fact, this may be an ideal job for the humblest of DPs bundled MAS plugins.
jlaudon
Post by jlaudon »
Thanks for your input - I did try the "telephone" setting in the MOTU eq, which was pretty close, but I'll incorporate your ideas with the freq and compressor, which should get it closer :)
vier-personen
Post by vier-personen »
frodos suggestions are great! you could even add a little distortion for the broken speaker effect, and add some noises to simulate bad radio reception - perhaps you can get something out of motus sonic modulator combined with the pattern gate and blend it to the original signal... experiment!
Timeline
Post by Timeline »
RAY GUN will do that
jlaudon
Post by jlaudon »
Timeline wrote:RAY GUN will do that
thanks- I bought Ray Gun a few years back (in the good ole days of OS9), and never jumped it up to OSX - just checking to see if I could upgrade, and the Arboretum site is down (gone?) - if anyone has an installer version of ray gun 1.6, let me know.
Jens
Post by Jens »
HI Jlaudon,
good way to try by yourself.Also you would find a lot of Speaker simulations
at altiverb app.
Jens
KarlSutton
Post by KarlSutton »
this may sound too obvious, but run the audio out through a small speaker & record it back
or try an amp simulator plugin
part of the effect in addition to the narrow bandwidth is the speaker sound
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
jrdmcdnld
Post by jrdmcdnld »
You could also record the real thing. Set up a radio in a room with a stereo pair of mics, and tune it between stations on the AM setting just to get the sound. Mix that in under your dialog.
daniel.sneed
Post by daniel.sneed »
Best way would be to search with your usual eq and disto plugins, and ad noises and hum.
But if you are looking for a good result in short time you could take a look at Izotp Vinyl (it's free)
http://www.izotope.com/products/audio/vinyl/
Very easy to set and rather convincing IMHO
Dwetmaster
Post by Dwetmaster »
If you want to stay inside DP, the preamp plug in has a setting you could start to experiment with.
martian
Post by martian »
load sample into reason...NNXT
map any knobs and faders you might have to a scream distortion unit....
the u tweak the 3 band eq setting with a couple of fingers
whislt another is randomly fiddlin with distortion type as loops it around endless;y -record all of these into DP... splice togther the best bits!
and there's always the resonance and cutoff filter... notchus gracias!!
I guess this sorta copies most of the above mentioned -tho generally I'd listen to any one who has hairy feet and are reknown for sitting around smoking pipes!!!
( the pipe finally makes use of the 3gig macpro I just bought,,,, an ashtray holder!!!!)
http://www.fork-media.com
David Polich
Post by David Polich »
