Really LOOOONG LATENCY problem
Dynamitastudios
Post by Dynamitastudios »
Hi there!
I‘m working a MOTU 896hd thru Windows XPpro sp2 on a MacIntel. I was working under AMD2800xp PC, and I had a terrible latency problem (it was more than 22ms on a buffer of 512!!!!). Now I have moved to MacIntel and I have tried all the ways, but it seems impossible to go under 12ms, which is unacceptable to a PRO interface. I‘m thinking serious to change this to another interface if I get no info about how to change this, and I would not get this answers from MOTU like "try to another computer" or "install new firewires"... I can‘t change my systems to work with this "problems-loaded" MOTU any time it doesn‘t wanna work!!!! :cry:
Please help!!! And of course thanks to you for reading all this words! :wink:
bigz203
Post by bigz203 »
With your buffer settings set to 256 you should be close to 5ms.
jazzcatt
Post by jazzcatt »
Dell Dimension Pro 3Ghz. 4Gig onboard. Reason 3.03 Ultralite
I am using an Ultralite, and for 2 months had no latecncy problems. I was down around 8ms, now , (as of last night), I have almost 500ms of delay. I've changed nothing! Any thoughts.
Paul1024
Post by Paul1024 »
Have any of you considered using the low latency CueMix?
--Paul
jazzcatt
Post by jazzcatt »
Paul,
Yes I do use Cuemix for remote recording scenarios, but my application where the latency is an issue concerns me using my PC as a Drum Module using the Reason Drum refills. I used to be able to play it just like a Roland Drum machine, and now , (once again reiterating that no changes were made,) have almost a half second of delay. I used to record out of the SPDIF outs, and those will not work either. Any thoughts,?
Thanks in advance for your time
