Para EQ missing time to time
steev05
Post by steev05 »
hey folks,
best wishes to everyone here for 2007, wish you lots of work, great tones and no DP crashes!!
i have a little problem with my DP 5.11, i sometimes use the para EQ plugins, pretty helpfull sometimes.. let's say i use it into a project then close it and open another one, and these plugins have disappeared, impossible to find it in DP and MW EQ is recalled "(mono) on the top of the menu chosen from the inserts.
also the name of the other plugins used do not appear in the inserts..
pretty boring, it does not crash but i can't use para eq anymore... any ideas?
the only solution i found is to reinstall DP 5.11 upgrade..
thanks,
steev
MacPro Quad 2.66GHz 4Go 667MHz RAM, DP5.1, Motu828Mk2, Melodyne, Ethno, Tascam US2400, AvalonAD2022, Focusrite, TCelectronics,..
Re: Para EQ missing time to time
steev05 wrote:hey folks,
thanks,
steev
First, let me get it straight. You're saying that DP is losing track of its plugins? When you open another file, the plugins are lost? And by that, we mean that when you click on a blank insert, there are no lists that drop down?
Ok, next question. Do you have more than one copy of DP on your hard drives? Could the other file be opening another (possibly older) copy of DP?
Do you install DP into the same folder as all your other applications? On the same drive as OSX?
I've never seen that behavior, so I'm just venturing a few guesses. Keep us posted on what you discover.
Dwetmaster
Post by Dwetmaster »
I was also told that it's better to trash the old plug-ins (or at least move away) before installing DP5. Because the new ones aren't erasing them. Especially if you had them all sorted in folders.
steev05
Post by steev05 »
hello,
DP is on my main hard drive with all the other aplications, in the application folder.
i have in that folder DP5, DP 5.1 and DP 5.11, but only DP 5.11 is used.
actually when i work on a project doesn't matter if i use some plugins or not, and Para EQ appears in the plugins window, if i close that project to open another one, Para EQ plugin (and only this one) would not appear any more in my plugins list.
i realize that it started happening when i installes Melodyne Cre8.
about the insert thing, if i click on it a list drops down but yesterday, a plugin was used on a track and didn't show it's name in the insert.
also, before installing DP5, i had no other plugins than the originals:
thanks for help,
Steev
steev05
Post by steev05 »
hello,
thanks for help,
Steev
Grigri
Post by Grigri »
Hello Steve.
I've send you a PM in french. The missing para eq syndrom is related to language of the OS. Let me know if it works
Grigri
Digital Performer 11.31 - Mac OS Sonoma 14.6.1
edb
I have the same problem
Post by edb »
Hello,
The missing ParaEQ phenomenon is happening on my system as well.
My OS language is german, if that is of any relevance.
When opening Konsole i get the following error:
"no MotuPluginTypeUUID valueCouldnt get factory"
found a way to get it back. I use OnyX to clean the kernel, user and system cache. After that i have to reboot and then everything works a before.
Very strange....
studiocubico
Post by studiocubico »
I‘m having he same trouble on my system (only on my Macbook pro), and anything seems to fix the problem: using onyx, cleaning and repairing, changing OS language (mine is spanish)... If I delete the masterworks eq bundle the paraEq is avaliable, but with no name in the menu...
Could it be an osX problem?
Has anyone found a solution?
Mac book pro 2,4-Osx 10.4.10-DP5.12
Mac Mini Pro M4 24Gb 15.3.2
Dp11.34
896mk3
8pre Firewire x2 - Driver version 1.6 89555
studiocubico
I don‘t know how, but it suddently seems to work ok again... I can see marterworks and dp eqs....very strange because I haven‘t done anything!!!
Dp11.34
896mk3
mixo
Post by mixo »
Same problem here,
Para EQ is no more in my plugin list.
I try to empty the MAS plugin folder leaving only the Para EQ inside,
the DP Plugin Menu now show the Para EQ with no names
(impossible to use)
Any Help?
GMarcelK
Post by GMarcelK »
I had the problem too when I was running OSX in Dutch.
Changing to English solved the problem.
If it's "missing", it's actually not missing, but nameless in the top of your plugin list.
But as far as I have experienced: the language....
Marcel
iMac | fast! | OS 10.6.7 | Ultralite MK3 | DP 7.22 | too many plugins
