i-DVD problem
David Polich
i-DVD problem
Post by David Polich »
For the first time, I'm using i-DVD to create some videos from camcorder footage I shot and then transferred to i-Movie.
I'm getting this error message when trying to burn a DVD -
"multiplexing error - the disc was not written".
This is when trying to burn a double-kayer DVD with about 4.8 GB of content on it.
Anyone experience this sort of thing?
Resonant Alien
Post by Resonant Alien »
What DVD burner are you using?
David Polich
Super Drive on my g5 2.3Ghz Dual Processor (the "older" Dual Processor, not the Dual Core).
I just spoke with Waxman and he recommended I burn a disc image of the i-DVD project first, then burn DVD's from that.
Resonant Alien
David Polich wrote:Super Drive on my g5 2.3Ghz Dual Processor (the "older" Dual Processor, not the Dual Core).
That's what I always do - burn the image first, then make DVD copies from that.
I use the same one on a dual 2.0 ppc. Works fine. Are you using good disks? Bulk disks can cause problems.
Resonant Alien
Does the SuperDrive in the G5s have limitations on media type? I know the SuperDrive in my G4 can only handle DVD-R, and not DVD+R.
David Polich
My SuperDrive has no media limitations.
I tried burning a disc image, but that failed too - right at the very end of the audio encoding process, the progress bar was at 99% - then, poof, i-DVD quits.
It may be that the data file sizes are simply too large - one "scene" is almost 45 minutes long and is 6GB uncompressed - perhaps this is just too much data for the cache to try and handle or for the compression process in i-DVD.
Also I am now constantly getting this message whenever I burn ANY dvd in Toast - the dvd burns successfully, but verification fails, with this same message:
"mismatch at byte 221, sector 661240, verification failed".
This is regardless of the content size I am trying to burn to the dvd. It's always the same byte and sector. I should add that the data on the dvd's burned with Toast loads back in just fine, it doesn't seem like the content is corrupted.
Maybe my SuperDrive needs cleaning? Although I don't know how one "cleans" a SuperDrive.
Resonant Alien
Have you tried burning a CD? Or have you tried a different brand/type of DVD blank media? Also, I am not sure how iDVD handles large files.
David Polich
CD's burn fine. I'll try some different media. Thanks for the help!
Resonant Alien wrote:Does the SuperDrive in the G5s have limitations on media type?...
Yes. It hates cheap disks or disks with any dust on them! :)
