UltraLite & DP 5.11
lampostudio
UltraLite & DP 5.11
Post by lampostudio »
I tracked songs in DP5.1 using two HD192's on my G5. Since then I moved the PCI card to another MAC and am using the G5 for mixing only using an UltraLite as the interface. The problem is when I try to change the output on "some" tracks from HD-192:anolog/AES1-2 to Main Out 1-2 UltraLite DP crashes and quits. It does not do it on all the tracks and I see no commonality in the tracks that it does it to.... any Ideas?
Al Chisare
Lamp Post Studio
www.lprstudio.com
lampostudio
More info
For some reason it seems to only happen in DP5.11 not 5.0 and it seems to some to be a conflict with DP5.11, Auto Tune & the UltraLite outputs.
If I open the same project in DP5.0, no problems at all.
Al Chisare
Lamp Post Studio
www.lprstudio.com
lampostudio
Hi, I really could use some help with this conflict is anyone else know what the problem could be between Auto-Tune, DP5.1 and Ultra-lite?
As long as I open the songs in 5.0 everything works fine. 5.1 no good, crash and burn...
HELP!!!!!!
Al Chisare
Lamp Post Studio
www.lprstudio.com
Hide
Post by Hide »
Did you try to get and install latest version?
I had problem but when I upgraded to latest version of Ultralite driver,
that was gone and working very smooth now.
emulatorloo
Post by emulatorloo »
lampostudio wrote:Auto-Tune, DP5.1 and Ultra-lite?
I thought I read threads on unicornation that
Autotune 4 MAS not working with 5.1
but
Autotune 4 AU working fine with 5.1
Could that be your problem?????
kelldammit
Post by kelldammit »
forgive me, as i'm not too familiar with AT, but also, if you've switched from a mas to an au version, afaik, the presets (if there are any in AT) will not translate.
so when you change the track's output to the ultralight, that track then comes "alive", and the AT plug will actually load and start up. it might be crashing due to the preset being unusable/unavailable?
my guess would be to unload AT on those channels, then switch the outputs, then set up a new instance.
kell
lampostudio
Thanks I'll give that a try.
Al Chisare
Lamp Post Studio
www.lprstudio.com
