How to do a quick mix?
emulatorloo
Post by emulatorloo »
James Wilsey wrote:Audio hijack needs to quit the program it's recording from in order to record from it-
Hijack Pro doesn't have this limitation
http://www.rogueamoeba.com/audiohijackpro/compare.php
Hijack Running Applications (Instant Hijack•„•) Hijack Pro Yes | Hijack No
Hijack pro is $32.00 vs 16.00 for Hijack.
My workflow was different than yours -- I started Hijack first, and then started my DP Session from Hijack. Hijack launched DP, I loaded my song and away I went. But if that isn't workable for you, seems like Hijack Pro might be.
666 suggestion also worth checking out.
Yay! Loo-ball hits a milestone! :D
Congrats, Toilet-wannabe; 1000 big ones. :lol:
Keep up the good work, bud.
Nicky
emulatorloo
monkey man wrote:1000 big ones. :lol:
Yikes what do I win?!?!?
Maybe this means I should take some time away. . .
Hey, 'baller
I'll throw in two more beers for my single toilet-boy transgression.
Doh! That'll 'ave to be 3 then.
I should have said, "Keep up the great work", BTW.
Glad I caught you, TB. :lol:
Nicky
James Wilsey
Re: How to do a quick mix?
Post by James Wilsey »
666 wrote:
James Wilsey wrote:I'm also just using a stereo audio interface for the moment (they haven't delivered my new one...)
What kind of interface are you getting? If it's one of MOTU's, you don't need AudioHijack. All you have to do is open MOTU Cuemix Console, and enable "Mix 1 Return Includes Computer Output." Then, enable a stereo track in DP and set the input to "MOTU Ultralite:Mix1 1-2" (this applies to my UltraLite; I'd imagine it's similar for other MOTU interfaces). This was a welcome surprise after I bought an UltraLite and read about it in the manual.
At the moment, I'm using a Toneport as the interface I ordered (Firestudio) hasn't arrived yet....Maybe the Firestudio will have a similar routing feature....
Thanks for the tip on hijack pro- it just might be worth getting.....
emulatorloo
James Wilsey wrote:Toneport <snip> Thanks for the tip on hijack pro
Interesting . . . that's one of the two interfaces I tested hijack with! Best of luck . . .
James Wilsey
Got around to trying it again- I used Hijack pro- worked like a charm, no relaunch required.
Thanks for the help-!!
Jw
emulatorloo
James Wilsey wrote:Got around to trying it again- I used Hijack pro- worked like a charm, no relaunch required.
Jw
Thanks for the update -- glad it works. I think I am going to get it too. . .
Happy New Year
