Problems using Motu ASIO in Windows XP
register
Post by register »
Hi there,
I'm Tom, I've just started using my traveller and I'm new to this forum. I'm using my traveller on a macbook pro. I've got it working great on OS X, however I work a lot in windows XP, using bootcamp to go between operating systems. I've installated drivers on both operating systems, but I'm having some problems in windows. With the Traveller connected, things seem to slow down significantly. The Mouse pointer occatioanally freezes its position. Trying to use the traveler with ASIO drivers in a sequencer (FL studio) it is very tempremental. It occasionally stops audio, and sometimes outputs a very loud, high sine tone for short periods. Has anyone else experienced / head of this happening?
I'd really appreciate any help.
Tom
Baptiste
Post by Baptiste »
PC: P4 630 @ 3Ghz / Asus P5GD2 Premium / 1GB Ram(Corsair Value Select DDRII 512 Mo PC4200 x2) in dual channel
OS on 160GB SATA150 7200rpm Maxtor HD / Audio files on 200GB SATA150 7200rpm Seagate Barracuda HD
Softs: Nuendo 3, Waves-Platinum Bundle v4.0.
MOTU 896HD, MOTU MIDI express 128 USB, Alesis ADAT Black, KRK V6 series2 monitors, Behringer T1950 Magician, Roland TD6-K, Korg X5-D, SPD20, Yam A3000, and my musicians... :mrgreen:
PS: Apologize for my bad english :lol:
Mika
Post by Mika »
I think the only solution so far is to unplug the unit, press the buttons a few times to dissipate leftover power, replug and apply the "reset to factory default" via the MIX button. That's what I've been reading while looking for the solution to my own problem :)
wsimard
Post by wsimard »
Hi !
I have a MacBook Pro C2D with a 828mkII and get that high pitched sound under XP via Bootcamp. I installed the hotfix, played with the registry value, reinstalled the drivers... I can't get rid of that high pitched note every approx 10 seconds (seems to be random).
Anything else I can do ?
Thank you !
Will
Macbook Pro C2D 2.33 Ghz, 2G Ram, 160G HD
828mkII ver 1.00
Stephent28
Post by Stephent28 »
I had some of these same problems and it turned out to be the firewire card did not have a TI or Lucent chipset. Purchasing a new card with the TI chipset solved all my problems.
kelldammit
Post by kelldammit »
this is strange. i'm using a traveler with osx and xp on a black macbook, and have none of the described problems with xp. are you using the 64 bit beta drivers, or the newest 32 bit release? are you on firmware version 1.07?
also, are you using bootcamp 1.1.2? i had some issues with 1.1.1, mostly with mouse-type stuff though. i haven't noticed any system lagging when i fire it up in xp with samp...
01ek
Post by 01ek »
I have an 828MKII FW with firmware 1.01.
Win XP sp2 bootcamp.
I get the same hightpitched noise every 5 or so seconds, randomly.
I've tried:
- uninstall reinstall with all the different versions of the motu drivers using the procedure outlined in Baptiste's post : http://www.motunation.com/forum/viewtopic.php?t=16293
- factory defaults relaoded
- reset voltage on unit, by switching back and forth.
- optical in/out reset by switching off and on in console
- installing the Microsoft firewire fix for SP2
- the registry tweak described by Batptist at: http://www.motunation.com/forum/viewtopic.php?t=16293
what shall I try next?
Why does it work for some and not for others? There must be a peice of the puzzle we are, or I am, missing here....
thanks....
alexander
wobbie
Post by wobbie »
out of interest....
can you make it screech on demand by hovering the mouse over the battery icon in the task bar?
cos thats what my pc laptop has always done. I fixed it by turning going to device manager, and disabling the ACPI battery (this has the side effect of the laptop now switching off when out of power rather than shutting down)
MOTU had me convinced it was the PC but I'm quite willing to believe its MOTUs fault.
