Hey All
I just got my 8pre and plug in and started recording. The session went well except when at the end I was unplugging my xlr mic cables and I could not get the cable out of mic pre 1. I pressed the button and it seems to be stuck. Has anyone experienced this? I'm at a loss here, I have only had it for 3 days and this has happened. Any suggestions?
8pre with mic cable stuck in jack
- TheCoalman
no suggestions but I would like to know what you think about the quality of the mic pre's. I'm looking at buying one but can't find any information about the signal quality of the pre's. good luck with your problem, did you buy it locally? if you did you could just take it back with the stuck cord and have them look at it, if they break it then you get a new one! : )
TheCoalman
G5 2.7 DP/10.4.11/3G RAM/DP 4.61/5.12/Mach 5 1.2/828/Express XT/UAD-1 4.2/Spectrasonics/EWSQ Gold/Sampletank 2.9
- Pappy725
Is the cowl around the three pins bent? I've had trouble with mic cables in that shape before. My suggestion is get a good grip on the 8pre (I want, I want!!!) and pull straight out on the plug. Good luck!
Stephen
Stephen
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
