Playback meter hovers at 50%...solution
With only 4 tracks of mono audio tracks (24 bit/ 96kHz), my G4 DP 1.25GHz now shows the Playback at 50%. This is with no plug-ins, VIs, etc.
It never used to be like this. I haven't changed anything lately either. Still DP 4.5 w/ OSX.2.8
I write to a separate firewire drive (7200 rpm, 200 gb).
I indexed both drives, ran disk utilities to verify and repair permissions...I still have to try zapping the p-ram...
Any ideas for settings?
Mac Pro 3,1 (2 x 2.8 quad core, 10GB ram), Motu DP 10.1, OSX 10.11.6 El Capitan, Apogee Ensemble, Motu MIDI Express XT
Re: Playback meter hovers at 50%...solution
Check your read and write buffer sizes. If the write size is too small, it would cause this meter to rise since it is a representation of the machine's ability to load ram with audio as it needs it.
Don't forget, at 96k, each track is double the data of a 48k track. And going from 16 to 24 bit adds another 50%.
Dual 2.0, OS 10.4.3, DP4.52, MOTU 828 MKII, IK Plugs, Plugsound, Mach 5, Waves 5.0.
Hey there Nixon,
When you accidently post multiple times, as you did, you can use the "edit post" command to delete the extra ones.
It's the symbol above the text area that looks like a pencil and paper.
<small>[ August 04, 2005, 03:45 PM: Message edited by: studio dog ]</small>
I've noticed the same thing with my playback meter. I hit play, even with just a few tracks and it jumps to halfway right away. Oddly, it STILL hovers at halfway with 16 tracks. Go figure.
MacPro 12core 64GB Ram 4 1TB SSDs motu 828mk3 DP 10.11
it would be interesting to hear from a knowlegeable person: does the cpu usage meter accurately tell you . . what- that you should turn off plugins before the meter pins on 100 percent and the program crashes? does the meter know about dual processors and UAD/Powercore boards? It seems to me that as long as the program doesn't crash and performance is acceptable, who the hell cares how high the meter goes? It seems like the meter at half-way just means there is enough processing headroom, and that maybe it's somehow able to co-opt more processing power if needed. Has anyone actually run into processor overload, and did the meter indicate the overload?
Mac Mini M2Pro, 16G RAM; Midas M32R Mixer; UAD Quad Satellite x 2, UAD Volt 2x2, Mackie MCU and XTx2 +; Korg Krome 73; Roland VR-760; Yamaha Drum Set; Fender Bass; Guitars & Amps Galore; Selmer MarkVI Tenor sax; Yanigasawa Bari Sax; Selmer SA80 Jubilee Alto Sax. DP11.
For what it may be worth. If you set the voice allocation in your settings to exactly the same number as tracks (audio) in your project, the playback meter will work correctly and display the filling of the casche (sp). This is not an athoritative answer, just something I have observed.
Peace!
Peace!
Mac Pro Quad "Nehalem" Xeon 2.93 Ghz-12GB RAM - OS 10.6.4-DP 7.21- & Logic 9.1.3 - MOTU 896HD- Apogee Big Ben-Tascam US2400-UAD2 Duo-Altiverb 6-Melodyne Editor-Autotune Evo-Plugins from UAD, URS, PSP, Abbey Road, Flux-VI's- LASS-EWQLSO-VSL-Kirk Hunter VS Pro-Kontakt 4 -Manley Voxbox, Brauner VM1, Soundelux E47C & much more.
