chirping hard drive...
- RCory
For some odd reason, my G4 dual 1.25 started chirping. I think it's one of the three hard drives inside the machine...
How can I tell which drive it is? Or is it something else??
C
C
you can open the side panel of the G4 to see if you can tell what's happening. Otherwise, you may want to shut down and remove your newest drive first-- chances are if it's the drive, it'll be the oldest one. Boot up again with the side panel open to determine the source.
If there's a CD in the tray, take it out to see if that was the case.
The only other moving parts would be the fan...
Could be mice..!!
Could be mice..!!
- twistedtom
No problem you should be able to use the drive utillity program < aplications - drive utility > and format the drive. You will select "erase". This will put the info on the drive you need.
- sdemott
As twistedtom said - the S.M.A.R.T. drivers are not installed, reformatting the drive using disk utility will add all necessary drivers. Just be sure to backup the drive first.RCory wrote:sdemott -
Thanks for this. One of the drives shows up as "Not Supported"
Is that bad?
C
-Steve
Not all who wander are lost.
